Bryston Mini Mono Amps?
0 Members and 1 Guest are viewing this topic. Read 6499 times.
drummermitchell
Re: Bryston Mini Mono Amps?
« Reply #20 on: 30 Oct 2010, 01:59 pm »
If you look at the 300-SST power pac and see how compact it is,I'm sure if you take a 3B-SST2,
4B-SST2(full size)and compress them down to say 5HX12-14"W with the same style as the full size,you'd have a superb looking mini monoblock.
If the powerpac can do 300w in that compact size,for sure it can be done in the same style as the full size versions only in a  smaller chassis.
I'd definately have 5 of em upstairs.
Gogo
« Reply #21 on: 13 Nov 2010, 01:38 pm »
Hey,
these Bryston Mini Mono Amp are exactly what I`m looking for!
For years I´m searching for relativly small Mono Amps to replace my old B&W MPA1 mkII Mono Amps.
The new Amps should not be deeper than 300mm because i use a USM-Haller 14" Furniture System to store my vinyl records, the BP-25 Preamp and the Mono Amps.
Bryston Mini Amps would be so great!
drummermitchell
« Reply #22 on: 13 Nov 2010, 02:46 pm »
I don't think it will ever happen :dunno:,I think were :deadhorse:, :deadhorse:,over and over :sleep:.
There was some interest,that's as far as it went.
Power pacs are quite compact and as my reply above,I think  mini mono's(compressed from the full size 3-4B would be the cat's ass....meeeowwww :thumb:..
rmurray
« Reply #23 on: 14 Nov 2010, 12:16 am »
Yes they would be my 4bst replacement I'm sure . :angel:
