Anyone using a SET amp with the de-capo i's
0 Members and 1 Guest are viewing this topic. Read 8326 times.
TIC
« Reply #20 on: 14 Mar 2004, 03:29 am »
Dave,
I hope I didn't spook you too badly. I only heard a stereo Zen, not a pair used as mono-blocks. They will likely be much better as the additional power will be useful with the De Capos. Remember, a single Zen select is only 1.8 watts/channel at best! Also, a stereo Zen likes a 2 ohm load best, but a mono-block setup may be different.
I do know that there are folks over at the Decware site that use De Capos with Zen amps and like the results. But, my experience with a single Zen and it's 1.8 watts showed me that a speaker built specifically for the unique design of the Zen, worked best.
Good luck! Hopefully it is a match made in heaven!
TIC
davejcb
« Reply #21 on: 14 Mar 2004, 09:40 pm »
You did for a bit :)
I'll post results soon enough.
