0 Members and 1 Guest are viewing this topic. Read 30261 times.
you will discover a truly different approachto LP sound—one that will reshape your perceptions about whatLP can and cannot do.
My biggest surprise is what a lightweight chairguy turned out to be when we started drinking
Purity Audio DesignHoly smoke (pun intended ) did that room sound good. 'woodsyi' implored me to go there with my dwindling time at show and, man, am I glad he done did It sounded sensational in there. Using Lowthers with separate tweeter units and bass enhancement in the corners, powered with his Purity Audio electronics it sounded creamy smooth and one could have stayed in that room for days and not been sonically fatigued. Delicious, just delicious it was.Lest you think I was pre-disposed to liking Lowthers (or single drivers in general), I assure you I was not. In fact, I was pretty much pre-disposed to hating them. But, the moral of this as it relates to audio is never to hold beliefs so close as to not open yourself up to other possibilities. John
Best sound of show, Bel Canto Room. Runner up - GR Research room. There's always next year.
Although I have no idea which Lowther driver Bill was using, you now have a sense of why I'm so passionate about my Lowthers. If you had a chance to go to the Lowther America room (on 10 as I'm told), Jon's room sounds a bit more like my rig...though I use 300Bs and tubed preamplificaiton....and you're exactly right, sonically non-fatiguing yet loads of detail. Just a pleasure to listen to....but then again, I'm pretty biased Glad you had a chance to experience Lowthers done well
I regret that I have to start this off negatively, but this years show was by far the worst since I started attending these 5 years, (I missed last years however), ago. This year was especially depressing as it was the first time Legacy and Naim attended the show. My system has a Naim amp driving Legacy Focus loudspeakers. Naturally I was excited to have the chance to hear the new Focus SE's, (which sounded mediocre at best), and the higher end Naim amps, which received my award of most pathetic sound at show.Several other rooms were relatively mediocre, but it seeemed to me it was because they really didn't put the effort into setup like they did in the shows before this. Best sound of show, Bel Canto Room. Runner up - GR Research room. There's always next year.
SoundSmith3 words: Strain Gauge Cartridge. The age old intractable and innate issues with phono cartridges have been mostly swept aside. It doesn't rid anyone of the inherent issues of analog/vinyl itself....but, it mostly removes the albatross to higher fidelity that standard phono cartridges have been. I have never heard cleaner, less jittery,fulsome and quiet recordings in my life. It made my Longhorned/shibata Grado's sound tepid in comparison...and I have found my Grado's to lay waste to a lot pricier cartridges over time. The strain gauge is the real deal - obliterating common obstructive elements of even the best and priciest moving coil, iron and magnet cartridges. Low moving mass - how 'bout no (as in ZERO) moving mass. Frequency response? DC to 70 Khz (you've never heard bass like this from vinyl and this spec is part of that reason) To borrow a line from Anthony Cordesman (gushing) review of the SoundSmith Straing Gauge in March Stereophile: Starting at $5500 for dedicated phono preamp (it does not work with the one you already own) and cartridge it's certainly a chunk of money. But, it was the largest advance in sound quality from the playback end that I have heard or are aware of. Digital and DAC designers....you're not obsoleted as you will always have convenience on your side - but any thoughts of besting the best vinyl playback has been set back at least a decade with the strain gauge in the race Yeah, I kinda' liked it John
Seriously, what were you guys who think the show wasn't that good smoking, or not smoking? Best RMAF evah! and by quite a wide margin too. That's coming from a very jaded long term RMAFer.
