Audio/Video Gear and Systems
All Solid State
Keep My Preamp?
Keep My Preamp?
doug s.
makin' music
Re: Keep My Preamp?
Reply #20 on:
16 Oct 2010, 05:50 am »
i had some pretty decent s/s preamps before i went tubular. electrocompaniet ec-1a, then linn kairn. these were really nice. but the melos ma333r i ended up with was more like real music, in comparison. that said, i can't say all tube preamps are the real thing. i would choose either the linn or the ec over rogue magnum 99, cary slp98 or audio research sp9mkll, the pre's i auditioned in my system before i found the melos. (this was ~15 years ago; i had it modded a few years back and it's still in my system; new preamps are one component i really don't have much interest in auditioning...
doug s.
Mass. Wine Guy
Re: Keep My Preamp?
Reply #21 on:
16 Oct 2010, 03:11 pm »
My audio terrain is the low end of high end. I can't afford tube or very high end gear.
doug s.
makin' music
Re: Keep My Preamp?
Reply #22 on:
16 Oct 2010, 11:38 pm »
Quote from: Mass. Wine Guy on 16 Oct 2010, 03:11 pm
i have never tried this preamp, but i have heard good things about them, especially w/a bit of judicious tube rolling. and, finding them for $400 or even less, is not uncommon, especially if you look for a used iteration. a bud of mine had one, and he a-b'd it with a respected vtl tl5.5, and actually preferred the dared. and, the ambitious can replace a couple of caps for even better results.
http://cgi.ebay.com/New-Dared-SL-2000A-pure-tube-preamp-USB-DAC-module-/260676496950
http://www.audiogon.com/cgi-bin/cls.pl?preatube&1291068538&/New-Dared-Sl-2000a-Pure-Tube-p
(same seller)
doug s.
flintstone
Re: Keep My Preamp?
Reply #23 on:
17 Oct 2010, 01:05 am »
I have an Adcom GFA 535 II in my computer system, and a Monarchy M-24 tube DAC/Preamp.........sounds great IMO. I agree with the wait, and listen first advice.
Dave
doug s.
makin' music
Re: Keep My Preamp?
Reply #24 on:
17 Oct 2010, 04:22 pm »
even tho you really need to by amp
immediately
you really
should
wait to give your new speakers a good listen w/your present gear before changing any other gear like amps/preamps...
doug s.
Mass. Wine Guy
Re: Keep My Preamp?
Reply #25 on:
17 Oct 2010, 06:46 pm »
I plan to wait a while. Silverline's site says the Minuets can be driven nicely with as little as 25w/channel.
All Solid State
Keep My Preamp?
