0 Members and 1 Guest are viewing this topic. Read 3593 times.
I have found the most important aspects of picking a sub is how it will work with the monitors. For instance, I have first order crossovers in my speakers and 4th order xover in my sub. For some reason this makes it really hard to integrate. I was told the reason by Roy Johnson but it was a bit over my head. I'm still learning in the crossover department..
I didn't hear anyone mention stereo, so I'm assuming it is correct that you cannot discern stereo with two subs...
wrong. listen to nusrat fateh ali khan/michael brooks "nightsong" cd. on some cuts, you'll hear low-frequency stereo that moves all over the room. i have *always* been able to localize a single sub, even when crossed over wery low, unless it's centered *exactly* between the monitors. and, soundstaging will suffer, unless crossed over at 40hz or lower, imo. having two subs will *improve* soundstaging, imo..for stereo, get two subs. the room interaction will be better, due to two different sourc ...
