Vertical Bi-Amping (Why does it work?)
Re: Vertical Bi-Amping (Why does it work?)
« Reply #20 on: 4 Jan 2019, 09:56 pm »
It depends on the receiver. My Marantz SR-6005 AVR has the ability to use 4 amp channels of my 7 available channels to biamp the front speakers. The other 3 channels are for the center and surrounds. Since they all use the same power supply, I would guess that this is not strictly vertical or Horizontal biamping.
celo
« Reply #21 on: 4 Jan 2019, 10:25 pm »
Thanks! So, what I understand is that even though the receiver is able to biamp, since it shares the same PSU, it is not a biamp that will give real advantage.
You need to use two identical (preferably identical), stereo amps to have the advantage (subjective but at least technically it has an advantage). Yes?
