Poll
OB dimension ?
Shape
0 (0%)
Mountig
0 (0%)
Total Members Voted: 0
Electro Voice Pro 12 B
0 Members and 1 Guest are viewing this topic. Read 8897 times.
stoN_Cold
« on: 6 Oct 2010, 12:02 pm »
I am New, ok!  :thumb:
That Loudspeakers stands about 5 years.
Now I have collect  courage to make OB with this beautiful Speakers  :wink:
Few suggestion will be fine!
Regads stoN_Cold
ga foo 88
Re: Electro Voice Pro 12 B
« Reply #1 on: 6 Oct 2010, 06:29 pm »
http://www.quarter-wave.com/Gallery/Gallery.html
about 1/3 down the page is an example.
Badwater
« Reply #2 on: 6 Oct 2010, 11:02 pm »
Go for it.  You won't be disappointed.
Pchelac
« Reply #3 on: 9 Oct 2010, 09:06 am »
Thiell Small parameters? Do the simm in Edge and in MJKs worksheets (Zen can help)...You can try them in open back box (Yamamoto style - http://www.6moons.com/audioreviews/yamamoto9/speaker.html ),anyway -to see if it works...
stoN_Cold
« Reply #4 on: 9 Oct 2010, 10:04 pm »
1/3 Ok, only Fostex & some others with Bass helpers, & one with 12TRX?!
No,No forbid!
I already have 10" B&C with wooden horn!
Zen can help
Not again
Regards stoN_Cold
ga foo 88
« Reply #5 on: 13 Oct 2010, 04:46 pm »
Maybe our computer screens are different sizes :green:
"Fostex T90A Super Tweeter, Electrovoice SP12B Wide Range Driver, and Eminence Alpha 15A Woofer in an H Frame "
that is the title of the pic in the gallery on mjk's page.
stoN_Cold
« Reply #6 on: 14 Oct 2010, 01:28 pm »
Thx, I saw too many loudspeakers.
SP12B is diffrent compared with PRO12B!
Regards stoN_Cold
Badwater
« Reply #7 on: 14 Oct 2010, 08:35 pm »
The EV system mentioned above is mine.  Concept using the pro driver would be the same.  I use a plate amp on Alpha.  The EV is cut at 200 using a passive 2nd order filter.  The Fostex uses a single cap with an L=pad.  I really need to take them apart and finish them. They have been in temporary wired state for over a year.  The plate amp I am using is the cheap Parts Express 70 watt unit which isn't up to the task. It hums.
Any how, my advise is to stick the your drivers on a board and see how they sound.  I think you will be pleasantly surprised.
Bill
