good used headphone amp for Sennheiser HD600
0 Members and 1 Guest are viewing this topic. Read 5818 times.
mitcho
« on: 6 Oct 2010, 06:06 am »
what would be a decent headphone amp for my Sennheiser HD600.  I want to spend less than $500 as I don't use them too often.
my last amp had a phono output, but the new one does not.  Miss them for late night listening.
thanks
BobM
Re: good used headphone amp for Sennheiser HD600
« Reply #1 on: 6 Oct 2010, 11:04 am »
Take some time and visit head-fi.com
There's a classified section over there with a lot of things being sold. You should find something that meets your needs at that price point. I built myself a Mini-Max for my 600's and couldn't be happier. They usually sell about $500 new, and somewhat cheaper used, or you could build it (and have some fun) for about $200-250.
Enjoy,
Bob
mbakes
« Reply #2 on: 6 Oct 2010, 11:45 pm »
Take a look at : http://schiit.com/products/asgard/
People that I trust tell me these amps perform better than their very reasonable prices.
« Reply #3 on: 7 Oct 2010, 12:20 am »
I have a highly modded X-Cans V2 with X-PSU that I might be willing to part with, since I have a custom tube amp being built for me.  The 600's really thrive with the X-Cans and XPSU because of the stout power supply, the control of the solid state output, and the musicality of the tubed input stage.
rwdrey
« Reply #4 on: 7 Oct 2010, 12:25 am »
Checkout the Little Dot MKIII. $200 new & tubes are cheap. Sounds wonderful with the Hd580s & HD650s. Head-Fi.org.
mitcho
« Reply #5 on: 7 Oct 2010, 01:01 pm »
thanks for the input.  I will check them out
BobMajor
« Reply #6 on: 13 Oct 2010, 08:07 pm »
I have a Headroom Max (2004 model) which I replaced with an Eddie Current Zana Deux. I've just been too lazy to put it up for sale on Head-Fi. I would sell it for $500.
mbakes
« Reply #7 on: 13 Oct 2010, 08:35 pm »
Off topic but I had a Zana Deux, what a great amp.  It was also a great preamp for the First Watt F1 I had at the time.
neergan
« Reply #8 on: 17 Oct 2010, 06:16 pm »
I use an Edirol UA-5 as the dac and phone amp from the digital out from a highly modded Toshiba SD-3950 transport. Fantastic sound.
neergan
« Reply #9 on: 28 Oct 2010, 07:23 pm »
vintage Marantz 1060 integratred.
saisunil
« Reply #10 on: 28 Oct 2010, 07:36 pm »
It will depend on your source - You may want to consider a portable headphone amp ... especially if you are using a portable source like ipod ...
dangerbird
« Reply #11 on: 28 Oct 2010, 10:30 pm »
I suppose that I am a dinosaur,,Singlepower PPX point to point wired(safety checked)  :D
Noseyears
  • SS-Audio
    • Supreme Sound Audio
« Reply #12 on: 6 Nov 2010, 05:16 pm »
Get a used HA-160...they are a good match for the 600/650's.
