I believe the AD8620 as a proper single opamp must be a misprint, with the author actually using the AD8610, a single opamp with the appropriate pin-out, as opposed to the dual AD8620, which would, in technical parlance, go all hinkey, and possibly, let the smoke out.[Wayne - are the rails on the EE within the AD8610 +-13 volt rail limits?]
Hi Guys, the NE5532 and its sub(dual) and NE5534 and its sub (single) are not compatible to each other. If you plug in the dual opamp to the sigle opamp place, and vice versa, it may damage your DAC.Cheers !Alex
*U1/U2 OPA827 (dual) and U6/U7 OPA2604 (single)It would be proper to recon this as one of the better combinations. My notes simply indicated, “Gorious! Perfect!” as it was a finalist. *The OPA2604 is not currently offered by Cimmaron. I believe it is an older Opamp; if sourced elsewhere Cimarron can use the Brown Dog adapter to make the Opamp for your Minimax.
*U1/U2 OPA2604 (dual) and U6/U7 AD797B (single)This was the big winner in my system, offering scrumptious sound for both the Legacy Audio Whisper DSW and Kingsound King speaker systems. I find precious little to nitpick about this pairing; it yields a mature, “full bodied” sound with plenty of crispness and detail but without a trace of stridency. *Again, one may have to search for the OPA2604.
Hi Doug,I urged you via email to correct a fatal flaw in your article, yet you chose not to address it in the least in your revision.As far as I understand, when the tube output is selected, you are listening ONLY to the op-amps in the U1/2 positions. You are NOT listening to the op-amps in the U6/7 position. When the SS output is used, you are listening to ALL 4 op-amps. Obviously this distinction must be made very clearly for each description of the sound coming from the unit.Therefore, unless you tell the reader whether each and every evaluation was performed with either the tube or SS outputs, the reader does not know which op-amps you were actually using. Obviously, since the reader does not know which op-amps are being used, any description of the sound quality obtained is completely meaningless.You say that "Because of what is to my ear a more pleasing tonality I have tended to use the tube output the most" If this is the case, why do you then go on to desribe the sound of sets of ALL 4 op-amps, two of which are not even being used? Or, maybe you were referring to the SS output, in which case you actually were using all of the op-amps you mention.The reader doesn't know, because you don't sayAgain, this renders any discussion of sound quality meaningless since we don't know what op-amps you were actually listening to.It is just as meaningful as saying that you have two preamps and three amps in for review and then describing the sound quality without telling the reader which pieces are being used!I don't know how to be any clearer that the current article says absolutely nothing about about how particular op-amps sound unless you tell us which op-amps were in use! You can fix this easily, by making two tables - One that lists the op-amps in U1/2, which were evaluated by the tube output. The second table will list the op-amps in both the U1/2 positions and the U6/7 positions, which were evaluated via the SS output. I think as a reviewer you would like the reader to know what is being reviewed. Such is currently not the case.Best of luck to you. I hope that the article can be revised once again so that you let can the reader know which op-amps were being used in your listening tests.-Mike
.......I do have 6 49990s on the way. Will be interesting...-Mike
Well, I have a VAC preamp at least!I'm afraid that the 49990s might be too lean 'n clean for my taste (and w/ the Cherry amp), esp. relative to the OPA2107 but we'll see.But I've taken the SS output too far in the rich, creamy direction (with some source material - with others it's oooh so nice) with the OPA627s. So I'd like to inject a lttle more air into things w/ the 49990s.If the 49990s don't pan out, I'm eyeballing the OPA827.
I installed my LME49990's the other night configured on Brown Dog adaptors as duals in the U1 and U2 positions and as single op amps on Brown Dog adaptors in the U6 and U7 positions. they are very smooth, clear and hyper detailed. mine have been running for 30+ hours. do these things have a break in period
