0 Members and 1 Guest are viewing this topic. Read 43033 times.
There are 2 pairs of opamps that can be easily changed on the EE dac.The first pair consists of dual opamps 5532. The dip version of the LME49720/LM4562 is a straight swap, and will serve as the I/V converter, feeding both the solid state output, as well as the tube's.The second pair of opamps are 5534, which provide the solid state outputs. These are singles, and as the compensation pins are not used, the LME49710 dip format is a straight swap.Both the 553x and LME497x0 chips are low noise bipolar input chips shouldn't present problems.I've used and like the LME497x0 series but can't comment on the efficacy of using metal can/browndogged single to dual boards, etc...
One thing though, (as Levi and others have said) is that the SS output is now much closer to the tube (RFT) output and sounds very good, w/ excellent dynamics and extension.-Mike
I find the TI chips to add a bit of warmth to the mids
