Bryston now has a BIT
0 Members and 1 Guest are viewing this topic. Read 104456 times.
klao
Re: Bryston now has a BIT
« Reply #20 on: 4 Oct 2010, 06:05 pm »
Yes they will be available in 230/240 volt versions but we probably will not do the AVR versions.
james
Awesome, James, I would also want one BIT for 230V!  Nevermind the AVR, but usually what's the voltage operating range for the 230V 7B-SST/2 before it shuts itself down by under/over current?
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #21 on: 4 Oct 2010, 06:28 pm »
The 7B would not shut down it would just deliver less or more power. Not sure on the 230v range - but the 120 is OK between about 95V to about 135V.
james
drummermitchell
« Reply #22 on: 4 Oct 2010, 06:41 pm »
James,I don't see WM series,do you mean RM=60a bal.
« Reply #23 on: 4 Oct 2010, 06:48 pm »
WALL MOUNT - 60 amp and 100 amp.
james
drummermitchell
« Reply #24 on: 4 Oct 2010, 07:20 pm »
NICE,we'll I see my 20a can get the facelift.
I'm assuming the owner can install the new faceplates.
BrysTony
« Reply #25 on: 4 Oct 2010, 08:06 pm »
OK, one of these goes on my list  :drool: but below the BDP-1  :D
larevoj
« Reply #26 on: 5 Oct 2010, 01:51 am »
Hi James,
Will it be possible to purchase the faceplate and mount it on the Torus?  :D
runs10k
« Reply #27 on: 5 Oct 2010, 08:30 am »
James,
          awhile ago you posted a thread asking if anyone liked the idea of a TORUS with a Bryston faceplate. At the time I did not respond as I looked at my torus and it seemed ok with the 2 color scheme. Now that I have seen a Torus kitted out with a Bryston faceplate, it looks more awesome than I would have imagined. I would vote AFFIRMATIVE in that survey. The picture you posted is using the black faceplate. Can I assume it will be offered in silver? And should I go a step further and decide to replace my Torus faceplate (RM20) A) what would it cost? B) would my dealer in Vancouver [Commercial Electronics] do it? OR is the Torus sent to Bryston?
« Reply #28 on: 5 Oct 2010, 10:49 am »
Hi Folks
Yes the faceplates are retro-fit-able. I will get a price for you and not sure what's involved in changing it.  There were two versions of the 15 amp Torus -a three rack space version and a 2 rack space version - so they would have different faceplates.
James
drummermitchell
« Reply #29 on: 5 Oct 2010, 03:29 pm »
Q for James,is it possible to have a custom faceplate done(knowing that it would cost more)
EX:RM 60a Torus :D.
« Reply #30 on: 5 Oct 2010, 03:42 pm »
EX:RM 60a Torus :D.
Hi Don,
I will ask.
james
drummermitchell
« Reply #31 on: 5 Oct 2010, 07:12 pm »
Thanks James,I don't mind payin :o :thumb:.
Tony1
« Reply #32 on: 6 Oct 2010, 12:31 am »
Looks great.  It would be nice if the switch was in the center bottom of the faceplate with a green light above it to be identical to the amps.
1ZIP
« Reply #33 on: 6 Oct 2010, 03:16 am »
Ya, that switch looks out of place.  Maybe a clear one with an green internal light?
alexone
« Reply #34 on: 6 Oct 2010, 04:22 am »
...what about a switch that is identical to the SST2 amps? maybe with a kind of green backlight??
al.
Tony1
« Reply #35 on: 6 Oct 2010, 04:52 am »
Like the 28B's look with one green light and the SST2 switch right below it.
Robert D
« Reply #36 on: 6 Oct 2010, 11:30 am »
We see that Buddy  :thumb:
Robert
drummermitchell
« Reply #37 on: 7 Oct 2010, 12:14 am »
I imagine the Bryston Torus faceplates would be around the same price as the SST faceplates $225.00
or a tad more :nono:,just guessin.......perhaps the custom 60a balanced is  225.00 :green: :thumb:.
adol290
« Reply #38 on: 7 Oct 2010, 03:10 am »
I assume the physical layout is the same as the current torus. It would probably not
 be cost effective to actually move the switch, without changing the existing design(but I could be wrong).
If so, then I also think the color of the switch would look better if it matched the green of the led on the SST2 amps. And not to bright as to be distracting.
My 2 cents.
« Reply #39 on: 7 Oct 2010, 11:44 am »
Hi Folks,
The above post is correct - the switch is where it is and we did not want to add additional costs by changing the layout.  We are going to have Blue and Green switches available.
james
