Is a switching power supply messing with my internet connection?
bikes and beats
 :cry:
I just tried to add an old Moodlab DAC to my Roku which I use to stream internet content to my TV/music system. I use its wireless connectivity and haven't had a problem,... until now. The "wall wart" power supply for the DAC is a 12V, 1.5 A switch mode unit. Since everything else is the same, I'm guessing this is the culprit. I really don't want to listen the Roku ruin my Pandora play lists with its internal DAC any longer. Any advice would be greatly appreciated.
-Mike
Wayne1
This Parts Express power supply will deliver 12 volts without switching. You will need to find a cable and connector that will interface with your Roku.
You could also look into a new or used SqueezeBox unit to replace the Roku for audio streaming. The Touch will give you the ability to send 24/96 files from your computer to your system.
bikes and beats
Thanks all!
etcarroll
Just got that PS for my SB, also needed  this adapter set:
http://www.parts-express.com/pe/showdetl.cfm?&DID=7&Partnumber=120-537
Pretty easy to setup, you pick the adapter that fits and stick it on the end of the power cord so the markings line up (+ ones), works great.
