Jazzman , Can you recommend a great amp for stats ? A member of the Audio by Vanalstine team is loaning me a amp he designed for a friend who has stats and it sounds excellent !
Mike, what amp are you using now? Your last photo showed an AVA 400R I believe.
It's a Bryston 4B3. I like it a lot. Great match for the Janszens!Other changes were moving the subs to just behind the listening chairs -- this got rid of a room null at 40 Hz -- and supplementing & rearranging acoustic treatments. In particular, the two GIK Alpha panels on the front wall are new, while two Vicoustic diffusers were moved from the front to the side walls (one seen on left).
Room looks awesome.Are those diffusers made with wood blocks? If so, how much do they weigh?
It's been since late 2012 that I posted a picture of my setup. I don't browse this thread that often, but when I saw Mike in NC's post from a month ago with his JansZen speakers I had to post again because we have some of same stuff. Maybe we were separated at birth. I also use both Vicoustic diffusors and GIK products in my room to support the JansZen Valentinas. The second picture was from before getting the subs (Rythmik 12G).
A phased array, wire-stator ESL mated to an H-baffle woofer:
