My TubePlanar system
If they sound as good as they look you're a lucky man.How heavy are they?
So easy to build as well!
Jazzman - WOW - those look great! How's the sound compared to the other ones you built?BTW: What kind of subs (?) are those you have on the side? - not sure if I fully believe in this (at least if considering my novice skills) Jazzman/jamesbos - so what would be an EASY build for a beginner to try out and what is approx the parts costs?
