Thanks for sharing measurements. Took me a while to see it, haven't figured out how to subscribe threads here.......
Don't quite understand what you're speaking about. If you click the "Notify" button on the thread you will be notified on every time there is a new post.
It's a bit difficult to compare to my own since you are using a Holm Impulse. I'm using REW5. Tried to do I measurement here with Holm, but something isn't right.
Well, I"m not using REW so don't ask.
Was going to share some printscreens of my measurements, but doesn't seem it's possbile to upload images here. Unless I've overlooked something,
Yes, I'd say you overlooked something. All that is needed is to properly size the image (I use PixResizer which is free) then select the first button on the lef of the second row and browse for the image then select upload. It's very easy. In fact, I find this site the best out of the others that I visit.
Also, if you're going to share your measurements you are probably best of doing that in a new thread of your own.
this forum needs some upgrade....
Actually it's the latest version
When showing impulse response or ETC, you need to measure for each speaker in case you didn't.
I've done much more measurements then I'm showing.
