0 Members and 3 Guests are viewing this topic. Read 363759 times.
Hi guys, is there a room reason or other reason people get the Nathan over the Abbey? It seems the only the $300 difference would lead to more Abbey purchases unless there is something Im missing
Well, I think that was about 3 years ago and the room at the Hyatt was the size of an elementary school gym ...
It's a $300 per speaker difference,or $600 speaker pair difference. The Abbey is superior in all ways however. I've listened to both. It is larger in size and that is what you give up relative to the Nathans.But make no mistake the larger GedLee loudspeakers are superior in smaller rooms than the smaller ones are. They are superior in maintaining directivity control. I asked this same question to Earl about 1 1/2 years ago.Anand.
Most loudspeakers have been designed to be facing out with little to no toe in. The GedLee loudspeakers are not like that...
Having trouble articulating my thoughts here, but I think you'll know what I mean. When most speakers are toed in hard the soundstage loses width and the imaging becomes adversely affected, so I am in agreement with your opening statement. I understand that a wave guide necessitates strong toe in, but how does that affect the width of soundstage compared to a regular speaker with very little toe in?I think another good question is every system and design is a compromise of sorts. What in your opinion are the trade offs with the GedLee / Geddes?
On top of these questions I have another. So, I purchase from Dr. Geddes and get the Abbey's and get 'em all setup. I take the measurements and adjust accordingly (to me). Is Dr. Geddes OK with reviewing measurements? What is the after sale service like?
I am not sure what "adjust accordingly (to me)" means, or what it would mean for me to "review" those measurements. If you buy a pair of speakers from me then each speakers is measured to insure that it works perfectly - no further measurements are required. I, of course, don't believe in "room correction" above the modal region, so the speakers should be setup in your room unmodified from what they leave my shop as. IN the modal range, if you buy my subs, I will tell your what measurements to take, then I analyze them with my proprietary software and I send you the parameters for a DCX2496 to optimally setup the subs for your particular room. If you choose to buy subs elsewhere then you need to do this setup yourself. But above say 200 Hz. no change to the loudspeakers should ever be done as the direct field has been designed to be flat and should not be changed in any way.Voicing the speakers is not something that I would ever condon so I guess you would be on your own for that.
I'm speaking of setup and tweaking the active crossover. That's it! I don't use a DCX2496 but use something very similar the Ashly 3.24CL. My DCX went bad after one year so I couldn't bring myself to purchase another. I'm speaking of just dialing the Abbey's to the subs...I guess you answered my question though.
I have done on REW to Earl and he has given me some advice, but the advice will be limited because he may not know how to adjust your particular active crossover that YOU are using, he is familiar with his subs and the DCX 2496. Anand.
A point that hasn't been made clear is that Earl does not encourage crossing over the mains; he runs them full range. Also, the subs are not crossed over in a traditional sense. In a multi-sub system, the crossover frequencies can be (usually are) different for each sub, the subs are all mono, and they are distributed throughout the room to average out modal variations.
Ahh. I didn't know that. How is placement of the subs decided?
