Best practices for use of SBS on WHS?
0 Members and 1 Guest are viewing this topic. Read 3951 times.
etcarroll
« on: 30 Sep 2010, 07:28 pm »
After playing with vortexbox on an old pc, I decided to go the SB Duet route, with ripping my music as flac to my WHS, which I just added 8 tb of storage to.
So, what best practices have folks found?
Here's where I'm at now;
I'll start with SBS 7.5.1 on the server, again music in flac.
will start with wifi - G to receiver till I get a long enough cable to connect receiver to an 8-port switch hardwired to the router.
Will most likely upgrade power supply based on findings here.
Eventually phase 2, open the receiver and upgrade parts there.
What else?
JEaton
Re: Best practices for use of SBS on WHS?
« Reply #1 on: 1 Oct 2010, 02:16 am »
You don't say how far along you are in the ripping process.  Before you begin you should install Squeezebox Server on either the WHS system (if you already have it) or to another computer.  Then rip an album and see how it appears in Squeezebox Server.  Once you decide how you want to rip your CDs (rip that first CD a dozen times if need be until you have the process down to science) rip a few more.  Again, see how they appear in Squeezebox Server.  Are they in the right order, do the artists appear correctly, are tracks in order, do compilation albums appear as such?  Only once you've figured out the process should you go all out on ripping hundreds or thousands of CDs.  It's not fun to put a couple weeks of work into it only to discover that you either want to rerip or retag everything you've done so far.
Download a good tagging program like Mp3tag so that you can modify and add fields to the file tags you end up with when ripping.  At the very least you will later find typos.  At the extreme you might find yourself retagging the whole library to get it to appear as you like in Squeezebox Server.
There are a couple of tagging details, some of which are unique to Squeezebox Server, that you may want to pay attention to:
  • To get all of the CDs from multi-disc sets to group together into a single album, add DISCNUMBER=n tags to all files in the set, -OR- do away with the 'disc' concept altogther and either number tracks sequentially through the whole set, or to keep the tracks in the correct discnumber/tracknumber order, prepend the disc number to the track number within the TRACK field.  E.g.
    1-01
    1-02
    1-03
    2-02, etc.
  • Do not add DISCNUMBER tags to single CD albums.
  • Multi-disc compilation albums (think about that one) also require a COMPILATION=1 tag in all files for the discs to group together into a single album correctly.  Not strictly necessary if you don't use the DISCNUMBR field, as mentioned above.
  • You can get artists to sort by firstname, lastname by using an ARTISTSORT tag.  It's possible to set up a saved 'action group' in Mp3tag to swap the names.
  • You can get 'guest artist' albums to appear under the lead artist by using ALBUMARTIST for the lead artist and then placing the individual arists in the ARTIST tag.  Otherwise, these albums will be determined by SbS to be compilation albums and stuck under the generic 'Various Artists' moniker.
  • You can use ALBUMARTISTSORT in the same way as ARTISTSORT.
Make sure you keep good backups.  When initially ripping the library and adding 10, 20 or more CDs per day I would backup every day or two.  After that, monthly backups should be fine.
If your library fits on one or two hard drives, this can be done relatively easily to external USB (or eSATA) connected drives using some type of directory mirroring software.  Microsoft Robocopy (command line), Microsoft SyncToy (GUI) and some other free and commercial programs all can do this.  You don't need to do backups using conventional backup software, as your library shouldn't change much over time (it may change if you make wholesale tagging updates) and you seldom need point-in-time backup and restore capability.
If you actually have 8 TB of data, backups won't be so easily done to external drives.  It's almost like being back in the days of swapping floppy discs or CD-Rs to do backups.  When you reach a certain amount of data the only feasible thing to do is to have another storage system at least as large as the original onto which you can backup.
I prefer the stable branch nightlies of Squeezebox Server, which contain small, safe bug fixes.  They're not official releases, but they tend to smooth over many of the small bugs that end up in every release.  When it's been 2, 4, or 6 months since the last release, the number of fixes can be significant. That would be version 7.5.2 beta at the current time.  You don't want to install them every day, but I've always found that the Windows SbS installations go smoothly for me, although I don't have experience running SbS on WHS.  From what I've read in the Squeezebox forums, upgrades on WHS do seem to be a little more problematic, probably due to the unique installer requirements.  I'd do them once or twice a month unless you run into problems, at which point "if it ain't broken" is probably the smarter course.
http://downloads.slimdevices.com/nightly/?ver=7.5
Ideally, the server should be wired into your network.  It won't improve audio sound quality, but it will avoid dropouts (which, arguably, is a sound quality issue).  In most homes without in-wall wiring that usually means locating the server near the switch/router.
firedog
« Reply #2 on: 1 Oct 2010, 11:34 am »
SBS for WHS is written to be installed and uninstalled through the add-ins panel of WHS; that's the preferred way of doing it.
You can install "regular' windows SBS on a WHS machine, but then there won't be access through the WHS control panel.
etcarroll
« Reply #3 on: 1 Oct 2010, 04:36 pm »
JEaton and firedog -
Great tips guys, thanks.
JEAton -
I have a 2tb box for limited backup of the WHS.
I've already ripped all classical and jazz via WHS' ripping program that was added in the last power pack. Still, the remaining rock accounts for over half my collection.
I put EAC on an old htpc for ripping 2 disks that were too scratched for the WHS ripper to deal with.
Server is hardwired to 8 port switch, as the Duet will be eventually. I have to make up a cable to reach to the next room from my office were the server resides.
firedog -
Where do I find the WHS version of SB server? I opened an account on SB forums yesterday, didn't see it mentioned in the WHS area.
Edit: found it, 7.5.1.whs.msi, is this what you mean?
« Last Edit: 1 Oct 2010, 06:30 pm by etcarroll »
etcarroll
« Reply #4 on: 1 Oct 2010, 08:05 pm »
Oh, and a long time ago I installed Firefly Media Server on WHS for iTunes streaming, guess I'll remove that first in case there's a conflict between the 2 media programs. I never used Firefly anyway.
JEaton
« Reply #5 on: 1 Oct 2010, 08:19 pm »
If you're talking about crimping your own patch cable, don't.  It's just too error prone.  Buy one.
etcarroll
« Reply #6 on: 1 Oct 2010, 09:49 pm »
Just installed SB Server - WHS, and promptly downloaded  Mp3tag as a few multi-disc sets are messed up.
Mostly not bad though.
etcarroll
« Reply #7 on: 2 Oct 2010, 04:10 pm »
Rats - looks like I've run into the 'receiver doesn't log into network' issue.
I finally shut everything down last night an put it away. I'll have to start from step one later today.
Looks like from the slimdevices forum this isn't an unusual issue. Not seeing a lot of people solving it however.
firedog
« Reply #8 on: 3 Oct 2010, 09:57 am »
My experience with SB units (all types, including Duet controller):
Most network problems are solved if you give each piece of SB hardware a static IP on your network AND you map it to the MAC address written on each device. The network then "finds" the devices consistently, and doesn't "lose" them again.
Got this from the slimdevices forum.
IMHO ethernet also works better than wireless. YMMV.
etcarroll
« Reply #9 on: 7 Oct 2010, 11:24 am »
Haven't been able to get SB setup - no receiver recognition. Been using wallwart from another piece of equipment.
Just plugged in new power supply, and was finally able to setup the receiver. The controller is updating it's firmware as I type.
Yay!  :D
eclein
« Reply #10 on: 7 Oct 2010, 11:36 am »
Success!!! :thumb: :thumb: Enjoy!
