Specs on MFW15 driver?
0 Members and 1 Guest are viewing this topic. Read 3802 times.
jparkhur
« on: 29 Sep 2010, 06:42 pm »
Anyone have the low down on the MFw 15 driver.  The FR would be great... jp
mojave
Re: Specs on MFW15 driver?
« Reply #1 on: 29 Sep 2010, 07:42 pm »
Danny provided the specs in another thread:
Who wants an MFW-15 woofer for only $79 each? See specs below.
Re                        3.04        Ohms               fs                           15.0        Hz
Le                        2.07        mH                   Mms                      235.2        grams
QM                       6.62                                Mmd                      221.6        grams
QE                        0.34                               Cms                       0.476        mm/N
QT                        0.32                                Rms                      3.356        N*sec/m
Xmax                  13.02        mm                  Vas                       458.9        liters
Pmax                   225        Watts                 SD                         823.7        cm^2
Bl                        14.08        Tm                  VD                        1072.3        cm^3
Coil Diameter       2.50        Inches               EBP                         44.1
Gap Height           0.375        Inches             Magnet Weight        112        ounces
Efficiency             0.44        %                     Winding Width       1.400        inches
SPL                     88.5        dB 1W-1m
