Which format
0 Members and 1 Guest are viewing this topic. Read 1352 times.
neyloj2
Which format
« on: 27 Sep 2010, 05:07 pm »
I have a Squeeze Box Touch, I use itunes ans just started using HDtracks. When purchasing from HDtracks should I use flac or aiff. which has better quality?
JRace
  • Greetings one and Everyone!
Re: Which format
« Reply #1 on: 27 Sep 2010, 05:57 pm »
theoretically they will sound the same.
FLAC may have more supported devices, but may not play back (unsure if still true today) in iTunes....
Cacophonix
Re: Which format
« Reply #2 on: 27 Sep 2010, 08:20 pm »
neyloj2,
Are you saying that you are using itunes to stream to SB touch? :scratch:
Didn't know that it was possible ... and you had to use SB server interface ...
neyloj2
Re: Which format
« Reply #3 on: 28 Sep 2010, 02:47 am »
I use the music stored in itunes to play through my SBT. I want to get the very best quality for playback that is possible and don't know enough about different files(mp3, flac,aiff) I understand hdtracks is hi def music so I wonder, should I use aiff or flac or something else. Newbie here, SBT is my first digital experience other than itunes playing on my pc.
Vincent Kars
  • The Well Tempered Computer
Re: Which format
« Reply #4 on: 28 Sep 2010, 09:11 am »
There is a practical aspect.
As far as I know, iTunes don't support FLAC.
There are tricks to get it to work (Fluke).
SBT supports FLAC but I'm unsure if it can play AIFF directly or that it needs Squeezeserver on a PC to do the transcoding (using QuickTime) to a SBT supported format.
Simply download or convert a track to both formats and check if you can get the tagging and the playback to work.
File formats, maybe this link is of use: http://www.thewelltemperedcomputer.com/Intro/SQ/audio_formats.html
