SN DAC with Panasonic DVD-A7 as transport?
0 Members and 1 Guest are viewing this topic. Read 2213 times.
davejcb
« on: 1 Mar 2004, 04:37 am »
Hi all!
Building up a system, just ordered a pair of Decware SE84C Select Zens, which will be monoblocked. Speakers may be Reference 3A MM de Capos-i-. Trying to decide what CD player to go with, was considering Ah! Njoe Tjoeb 4000 with upsampler and Rega Planet 2000 until I came across this site and Scott Nixon DACs.
I already own a Panasonic DVD-A7, which is quite a nice player, 24bit/192khz, DVD audio, etc... It was 999$US retail price when it came out, so not a piece of junk.
What I'm wondering is whether anyone has use a Panasonic unit similar to mine as a transport with the SN DAC? I'm not sure how good the transport unit is on the Panasonic, we know Sony and Philips are good, but I don't know who makes mine, couldn't find any info.
So any input anyone? Would this player make a good combo with the SN DAC?
scottnixon
    • http://www.scott-nixon.com
« Reply #1 on: 2 Mar 2004, 03:47 am »
Have used a Pana A10 with pretty good results.   For whatever that's worth to ya.   sn
davejcb
« Reply #2 on: 2 Mar 2004, 04:42 am »
Scott,
Thanks for your reply! I can't seem to find any info on a Panasonic A10, only on a Technics DVD-A10, as mentionned on:
http://www.digitalaudioguide.com/dareview/technics/dvd-a10.htm
This came up on a Google search for 'Panasonic A10'. Is this the one you are referring to?
bubba966
« Reply #3 on: 2 Mar 2004, 04:43 am »
Panasonic & Technics are the same company. So that's probably what he meant...
davejcb
« Reply #4 on: 2 Mar 2004, 04:51 am »
Yep, looks like they're the same unit, check this... Good stuff.
davejcb
« Reply #5 on: 2 Mar 2004, 04:54 am »
Found this, for archives I guess... I think I'll go ahead and try it with the SN DAC and see.
bubba966
« Reply #6 on: 2 Mar 2004, 04:55 am »
The A10 was supposed to be a pretty nice deck.
So if Scott had good results w/an A10, I'd bet that you'd have good results with the A7.
