0 Members and 1 Guest are viewing this topic. Read 227078 times.
Has anyone else read the "History" section of the new Zu audio website (http://www.zuaudio.com/#zu-audio-history.php)? The section labeled "2010 Q4" offers interesting insights into the past few months at the company, and might help explain their recent price fluctuations. Sounds to me like they'll never again offer the kinds of sales that we saw this past December.
I couldn't pull up the history link. Has it been removed?
I couldn't pull up the history link. Has it been removed? I bought the Omens at their intro price of $999 but would not have paid $1500. The Tekton Lores currently priced at 1K also have a tricked out Eminence 10 inch driver but with the highly regarded Audax super tweeter and a 8ohm load.
Do you regret your purchase of the Omens? Do you wish you would have gone with the Lores? Based on what I have read, I think the Lore is going to be the better speaker sounding but the Omen looks nicer if you ask me. Unfortunately the WAF matters. I'm a little afraid to purchase from Zu, they are sounding very AV123ish to me.
I returned the Omens only because I was "outvoted" due to WAF and furniture compatibility issues
ha! I am headed down that route. I have picked up a set of these from Herbie's audio lab to try out.http://herbiesaudiolab.net/studgl2.jpgI am hoping to be able to scoot the omens out of the way when the boss doesn't want to see them. I have some vibration issues due to being on hardwood floors over a crawl space...so I am attempting to kill two birds with one stone.Sean
I used black granite tiles from Home Depot atop industrial ribbed carpet squares glued together. This makes the Omens easy to move around. The legs are lag bolts inside plastic feet also from HD.
Ah, Poultrygeist, that's you who suggested the tiles and ribbed carpet solution. Very nice looking solution, especially with those plastic feet. Which HD dept are those plastic feet found in? Do the lag bolts just slot in or screw into the feet?Any chance of a close-up pic of the plastic feet? Thanks.
The plastic cap feet are on the same isle as the lag bolts ( not lag screws ) at HD. The plastic caps are white and I spray painted them silver to match the lag bolt legs. There are several sized plastic cap feet but only one is a nice tight fit for the 3/8 lag bolt heads. I can't recall the length of the lags but they are in one of my earlier posts.
