Lastly, based on my experience with the Jr., the unit was broken in after 24 hours of continuous signal. After that, there may have been minor settling in, but the majority of break in was complete.
Okay, I have a minute. First, a few questions.I tried the XLR adapters (for the inputs) without the extra ground lift attachment, and it sounds fine. Is that okay, or do I need to put the ground lifts back in? I'm guessing that if there's no buzz, then I don't need the ground attachments.The input impedance is 10K, right? I dug around and found another post with that, but I though I'd double check. I'm using stereo Vandersteen 2W subs with the adjustable M5-HP crossovers, so I need to set those up properly. And finally, is there a break in period? It sounds great now- I'm just curious if it's going to get better
Regarding the ground lift, we include those now because many preamps aren't connected to earth ground. In that case, removing the ground lift fixes hum issues. This is a topic I have written about many times, but maybe a long-winded explanation is in order (someday when I'm feeling extra-energetic).Thanks for the compliments, and enjoy the sound!
Actually, mine doesn't have a hum that cuts in and out, so maybe it's normal. Does your Cherry Plus make any sound at all? Is it completely silent?I have one more question for you- what do your binding posts look like? Do they have the clear plastic knobs like the WBT's or are they solid gold?Thanks!-Philwww.philpalombi.com
That topic would make for a good sticky for your Circle Tommy. Cheers,Robin
Yes! Now if I can only figure out how to do that (haven't before)... Hmmmm.
