0 Members and 1 Guest are viewing this topic. Read 32096 times.
Well, I pretty much solved the issue of needing a commuter car myself, I don't drive to work, I walk to work. Mileage, smilage. For long distance stuff I still appreciate my 350 HP Audi S6 Avant. It is over three times heavier than my 1956 VW and ten times as powerful and uses only 1 2/3 gallons more gas per hundred miles on long distance driving (20 mpg vs: 30). Safety and comfort, no comparison. I will be packing it up in a couple weeks with a huge load of audio equipment and be off from St. Paul to Denver and the RMAF (1000 miles) and make the trip with Dean Barnell in an easy one day drive averaging near 70 mph (and I am 72 years old).There is no hybrid or electric car out there yet that would allow me to do that (and darn few conventional cars either). Maybe in the future, but not yet.Regards,Frank Van Alstine
Uhh, this is not a debate over "my super car is better than your super car". Regards,Frank Van Alstine
Danny, I've been saying this for years. I worked for Honda in the early/mid 90's.They had 45+mpg vehicles all through the 90's. The 93 Civic VX got 48mpg if I
if I want to such as Soy Methyl Ester (not saying this is a solution). Plus in case of the apocolypse I can run it on kerosene or used moter oil. 13gallon tank that I fill every 615 miles.
Miles per gallon is an exponential function.
By the way, thinking about fuel economy in miles per gallon is very very misleading.Miles per gallon is an exponential function. A much more realistic way is to consider economy in "gallons per hundred miles". This will give you vastly more intuitive way of thinking about fuel economy.For example, how important is it to increase your mileage by 10 miles per gallon?If you look at miles per gallon, you will be seduced to thinking that going from 30 miles per gallon to 40 miles per gallon is a big deal. It is not. You are going from 3.33 gallons per hundred miles to 2.5 gallons per hundred miles, a savings of just over 1 gallon per hundred miles. Should you spend a bundle up front to do this? Not hardly.Now at the other end, if you have a bottom feeder RV monster getting 5 miles per gallon, what if you could increase its mileage 10 miles per gallon, to 15 miles per gallon? You would be going from 20 gallons per hundred miles to about 6.66. A savings of over 13 gallons per hundred miles, big numbers and dollars saved here!I really don't understand the mentality of many over the road truckers who still blast by me at 80 mph on the open freeways in the mid-west getting 5 miles per gallon. If they slowed down to 50 mph they would save a ton of fuel money, and maybe even be within the limits where there could safely make a panic stop. We tested that at the Minnesota Highway Department years ago and found that at 60 mph, almost all truck brakes would melt in a true maximum braking effort (braking as hard as possible without locking wheels fromn 60 to zero). There is not enough iron mass in the brakes to deal with the heat load from the mass of the truck. Do the math, not a single trucker would volunteer to do the actual road tests for us. Oh well that's another story.Regards,Frank Van Alstine
It's a big deal to me. To me it's not just a matter of money. It's a matter of conservation and dependence on foreign oil. If everyone in the U.S. improved their mileage by 10 mpg, we could completely eliminate the need for oil imported from the Persian Gulf. Now granted I would prefer all electric but improving mileage is a good start.
