20 amp receptacle
0 Members and 1 Guest are viewing this topic. Read 6275 times.
mclsound
Re: 20 amp receptacle
« Reply #20 on: 26 Sep 2010, 08:49 pm »
hi L
there are plenty of empty spots and the amp was testing the waters with Vogue ,so I am sure it was well past 2400watts if the speakers have a nom. of 4ohms.
linyanti
« Reply #21 on: 27 Sep 2010, 12:32 pm »
Rereading the thread I see that srb posted that the receptacle amperage must match the circuit breaker amperage if it is a dedicated circuit. Canadian codes may be different.
My heartburn with the situation is that after looking at the manual the only place where I see a UL decal in the product photos is on the power cord made by Carol.
If this amp does consume more than 20 amps routinely it should have a different plug and definitely should not have a 15 amp plug. The photo does not show the plug since that is probably changed depending on the region that it is shipped to.
But these guys make a lot of amplifiers so they must know the rules.
Speedskater
  • Kevin
« Reply #22 on: 28 Sep 2010, 04:35 pm »
So I was in contact with Krell today and Ray and Walt say 30amp breaker,10awg wire,and a 20amp receptacle is what we want.
Did  Krell explain how to do that and still follow NEC Table 210.21(B)(3) ?
