Line Arrays
0 Members and 1 Guest are viewing this topic. Read 2972 times.
Jfondell
Line Arrays
« on: 18 Sep 2010, 11:37 am »
Hi all, I have a few questions concerning Line Arrays. I have a dedicated theater room 15x20 which I set up a 7.3 surround system. I have the upgrade itch and I am very interested in the Line Arrays. That being said I cannot build speaker cabinets let alone finish them so I would need the cabinets finished and ready to assemble.
Is my room to small for Arrays?
What is the cost for Cabinets?
I listen to mostly rock music, would these be good and if so what array would you recommend?
I want to be able to play at reference levels without distortion.
3000-7000 price range
Thanks for the replies
James
opusthepenguin
Re: Line Arrays
« Reply #1 on: 18 Sep 2010, 03:17 pm »
Our room is about that size and our arrays work great. We have 50 watt tube amps and they play loud enough without distortion to drive me out of the room and I like to listen loud. I've had no regrets about arrays and Rick is great to work with.
Jfondell
Re: Line Arrays
« Reply #2 on: 18 Sep 2010, 03:25 pm »
Great because your Array's are exactly what i was thinking of building Any idea on the price of the cabinets?
Rick Craig
  • Selah Audio
    • http://www.selahaudio.com
Re: Line Arrays
« Reply #3 on: 18 Sep 2010, 03:37 pm »
The cabinet cost will vary according to what options you choose (veneer,hardwood trim,etc) and your location (shipping cost). Feel free to PM or email and I'll be happy to help.
Rick Craig
  • Selah Audio
Re: Line Arrays
« Reply #4 on: 18 Sep 2010, 04:20 pm »
Forgot to add - I'm working on a new array technology and testing some modules this weekend.  :thumb:
PDR
  • May the best man win
Re: Line Arrays
« Reply #5 on: 18 Sep 2010, 05:14 pm »
I have Selah Symmetrica arrays as L&R fronts
Selah 128 arrays for rears, Selah Sardonyx as a center,
and 2 Selah dual 12" powered subs.
Powered with Sunfire 5400 and a Sunfire TGP-5 pre/pro
This is one of the finest 5.2 systems I have ever heard.
I would highly recommend Ricks arrays.
Jfondell
Re: Line Arrays
« Reply #6 on: 19 Sep 2010, 02:12 am »
Thanks, I also use all Sunfire equipment. I have a Theater Grand and 2 250x2 stereo amps for the front channels as well as the TGP5
I can see his Arrays are very highly regarded on several boards. I like the designs, like to play loud, and I want it to sound good. I want the rock concert experience in my house. I use my room for 70/30 music then theater. Over time I would like to have a setup with all Selah speakers.
