Who has tried HiFi Tuning fuses in their Bryston amps?
0 Members and 1 Guest are viewing this topic. Read 58689 times.
werd
Re: Who has tried HiFi Tuning fuses in their Bryston amps?
« Reply #120 on: 6 May 2015, 12:08 am »
Hey Folks, sorry I have been out of action lately!~  :lol:
huwm, I guess you got all the answers you need. PM me if you need more details...
After earlier post I changed out 6 more fuses in all my electronics with Hifi-Tuning Supreme. The net gain is similar to my earlier post and adds up to one word - Refinement.  :)
One word of caution though. I don't recommend Hifi Tuning Supreme if its a Full Tube setup. In fact for Tube electronics I find the Furutech Rhodium fuses does a better job in balance. Of cos its a bit of preference here too.
Finally, I highly recommend folks with Bryston amps to consider the following for the amps to perform its best:
1) Isolation Platform - e.g. SRA
2) Fast Power Cord - e.g. Audience E or SE
3) Quality Fuse - e.g. Hifi Supreme
4) Power Isolation - e.g. BIT or Torus
All of the above provides a cumulative gain in the amplifier performance versus many other amplifiers I have tried and I can attest to it especially in my case the Bryston 4BSST2 in UK specs.
Enjoy your music ~  :thumb:
You put the fuse in the soft Start? The 4B uses a rocker. You heard a difference, I am into fuses but I thought the rocker would squash any benefit? Guess not.
planet
« Reply #121 on: 6 May 2015, 01:10 am »
Sorted!
You're right, takes either
Had a 5mmx20mm AMR 6.3A to hand
Well impressed, will have proper listen tomorrow
Hi, can you share your finding? Thanks.
G Georgopoulos
« Reply #122 on: 6 May 2015, 01:44 am »
The most important specs of fuses are its resistance
and blow current,the resistance effects signal current
while blow current effects safety...
High quality fuses perform better and have
better stereo imaging...
And as JohnR says "live and let live"... :green:
planet
« Reply #123 on: 7 May 2015, 08:08 am »
Anyone can advise what type of tool needed to remove the square screw on top of the 4bsst cover? Thanks
« Last Edit: 8 May 2015, 12:23 am by planet »
Baroque
« Reply #124 on: 12 Dec 2016, 12:24 am »
Hi, after that I changed the fuse in my Magnepan with very good results...
This weekend I did in my 14b SST2 (Hifi tunning) and my BP26 (SR20).
Very please whit my sound now...more relaxe, more feeling, more live!
Why I did not changed before for $50?!?  :o
In my system it was magic... :P
