0 Members and 1 Guest are viewing this topic. Read 40577 times.
I replaced a Cary SLP-05 with a Dodd Audio Buffer.http://doddaudio.com/BatteryPoweredTubeBufferPreamp.aspxI think you should also put a "Dude" on your list. http://www.tuberesearchlabs.com/products/dude.html
Why no love for the Cary?
Next year is going to be a much better year, however, I will be pre-less come Friday afternoon.Under consideration are the following units, pretty much used is more affordable, and I'm considering both stop-gap units and higher possible-keepers in the tubed with balanced outputs group (remote vol is a plus):Ear 868Audio Note XX?BAT VK51SE or 31SE or 32SEPurity One or ReferenceNagra PLP (a little above my range)Atma-Sphere MP-3VTL 5.5 (probably a stop gap)VAC xx??Cary SLP05Cary SLP2002 (probably a stop gap)Aesthetix CallistoBelles 21A (probably a stop gap)What experience do you have with any of these in the up to $5k used or new area? Or suggestions?Using BATVK500 amp.
I currently have an EAR 868 with phono. Superb in my opinion
Out of all that you've mentioned, I would go with Shindo Aurieges. I've heard the Callisto, VTL 2.5 (IT-85 as well) and BAT VK 31SE, and the Shindos are the most transparent, with great S/N ratio. Actually, with your budget, you can probably get the Monbrison used, which is a bit more refined than the Aurieges. I've heard great things with EAR and Atma-Sphere, but never heard them. All the best,Ian
It does not have a remote, but I would highly recommend the SAS 11A
