0 Members and 1 Guest are viewing this topic. Read 16046 times.
Steve-I only got the triple beam...damn!!! I knew I shoulda got the quad...
That's okay, 75% reduction (of a possible 100%) in noise floor and high frequency glare is better than none! It will be interesting to hear more comparisons of this CD player with it's unassuming internal NOS DAC to computer playback + external DAC, especially with direct A/B switching between the two sources on the same songs. Steve
I read about it in a couple of places... the following quote is from TNT...I gave the M1 a few days to burn in, leaving it running on repeat to clock up around 80 hours before I actually listened to it seriously. The M1 does take a while between closing the CD drawer and being ready to play. At first I thought that there may be something wrong with the CD that I put in but it was the same with all of them. It took in the region of 5-15 seconds (depending on the CD) before the display came up and the music could be started. Given that you don't put CD's in for every track, this wasn't too much of a problem, although it did remind me why I love my Logitech Squeezebox so much!
The Maverick Tube Magic is as good of a buy as the Piano if the truth were known. But I listen to my FLAC through a Eastern Electric DAC or Tube Magic or through the Piano straight to my pre. My preference is the Piano direct with no external DAC to my pre..One quick note is that if you are looking at an office or secondary system the Maverick Tube DAC is almost without compare.
don't know where he got 5 to 15 seconds to play a disc. as i said only on the initial startup does it take a while before the info is displayed, after that about 3 seconds. ask any m1 owner or get in on the tour and time it yourself. i don't count the time while the tray is closing unless it just sits there and looks at me before it starts to move. i haven't read anywhere that a piano m1 owner was complaining about the time it takes to read a disc. read my review athttp://www.stereomojo.com/Virtue%20Audio%20PianoM1%20Cd%20Player/VirtueAudioPianoCDPlayer.htm
The whole thing about a delay is a NON-issue as far as I'm concerned, the unit itself is very solid and extremely well built. Easily the nicest piece I own and the sound is excellent. I'm listening to Jean-Luc Ponty and the dimensionality and dynamics are incredible. The subtleties and nuance in the music are more apparent and nicely presented. Spatious is a good way to put it, the DAC in this piece is wonderful...I haven't done a direct comparison yet to playback of wav files via my SB but I don't recall hearing such fullness and rich musical landscapes as I do with the Piano M1. I'll post some pics later on, they are great looking pieces!!!
.. a direct A/B is a challenge, so I played some tracks via the SB and then the same ones via the Piano M1 and took some notes.
Your method does not provide a direct comparison. Sorry, but direct A/B w/ matched levels.
