Can iPad or Touch do this with iTunes?
0 Members and 1 Guest are viewing this topic. Read 1651 times.
Alwayswantmore
« on: 28 Aug 2010, 02:56 am »
I have Macbook / iTunes. I want to purchase a Touch (or iPad if needed). Is there a way to use Touch or iPad to modify data fields in iTunes? I would like to do file maintenance on my iTunes library without using the Macbook keyboard.
Thanks, Kent
skunark
Re: Can iPad or Touch do this with iTunes?
« Reply #1 on: 28 Aug 2010, 08:10 am »
At most all you can do is rate the songs that are synced to the device...  If you have an airport express or the apple tv controlled by the ipod touch/iPad, you can't even do that.
Now what you try to do is run VNC on an ipad and connect to a computer running iTunes and edit the library that way.
« Last Edit: 28 Aug 2010, 06:26 pm by skunark »
Alwayswantmore
« Reply #2 on: 28 Aug 2010, 02:38 pm »
At most all you can do is rate the songs that are synced to the device...   You you used airport express or the apple tv, you can't do that.
Now what you could do is with an ipad is VNC into the computer running iTunes and edit the library that way.
Thanks. Found some apps on the Web. Looks like they do what I need. Kent
lokie
« Reply #3 on: 7 Sep 2010, 07:25 pm »
What are the aps?
Alwayswantmore
« Reply #4 on: 7 Sep 2010, 08:57 pm »
What are the aps?
Google VNC and ipad or itouch. Several bubble to the top. For example... http://www.realvnc.com/products/iphone/index.html
