0 Members and 1 Guest are viewing this topic. Read 21473 times.
Pass B1 buffer/preamporDodd buffer/preamp
Oatley Electronics K272A preamp/headphone amplifier. An amazing value at $30. You can roll Op-amps to custom tune the sound. HEre is my build ...
Does anybody knows if there is some place with a complete B1 Kit?????
There are a few kits on ebay you could check out. The tube buffer + preamp sold by Arjen Helder is supposed to take out the sharpness/edge of tripath based amplifiers. ANyway here are the links :1. Arjen Helder's integrated tube buffer+preamp2. Jim's audio B1 Kit1st option comes fully built with tube included. All you need is a 12V battery or a regulated supply ranging from 11.5 - 14V.I received Arjen's tube preamp yesterday, so if anyone is interested, I could provide a comparison of that vs Oatley preamp.
I think the Bottlehead Quickie would be perfect for what you're after. They have a great forum as well that is very helpful.www.bottlehead.comCheck em out.
How does all this compare to the Tube preamp you also linked to?
The 4 X 1K signal resistors can be upgraded without breaking the bank, and the reports are that doing so nets out a nice improvement in sound quality. Also, some of us have set up battery power systems rather than using the wall wart power supply, with improved sound quality as well, and this can be done for anywhere between $30 and $50. Even though it's lengthy, I'd recommend you read the whole "Nelson Pass B-1 Preamp Build" thread elsewhere in The Lab section for more sound advice from fellow B1 enthusiasts.Neil
Thanks for the response. I have skimmed through the whole thread & will do so again when time permits. Are there any suggestions for component changes like what you have stated that can be put in point form in this thread?
