The Stacked Baltic Birch N2X Ideas and Assembly Thread
0 Members and 1 Guest are viewing this topic. Read 52791 times.
jeffh
Re: The Stacked Baltic Birch N2X Ideas and Assembly Thread
« Reply #100 on: 27 Jul 2011, 12:31 pm »
which one is oil and which one is water?
praedet
« Reply #101 on: 27 Jul 2011, 02:06 pm »
I will guess based on my own speakers, left is oil right is water...
wagnju
« Reply #102 on: 5 Nov 2011, 04:06 am »
Any updates on the build  :drool:
brandon w
« Reply #103 on: 20 Jan 2012, 05:07 pm »
I bought a baltic birch kit from danny, back in december.  I just now am finding the time to get them assembled.  your's look great.  have you made any further progress?
praedet
« Reply #104 on: 25 Jan 2012, 06:28 pm »
One of them is sitting waiting for me to do the final sand and polish steps.  I thought I was there, then barely went through the finish in a few spots, so I added another 5 layers.  Hopefully that will be good this time...
I am walking up from 1000 Grit to 2000 Grit wet sanding, then doing rubbing compound, then polishing, all the way to wax.  So, my arms get tired...
persisting1
« Reply #105 on: 26 Jan 2012, 12:16 am »
Just think of it as a workout.  No need for a gym.  No pain, no gain  :lol:
praedet
« Reply #106 on: 12 Feb 2012, 10:57 pm »
All right, I know it has been a long time.  I am not done polishing, but here is one of the speakers on the order of 90% done with respect to looks and finishing...
Danny Richie
« Reply #107 on: 12 Feb 2012, 11:29 pm »
Wow!
DeeJayBump
« Reply #108 on: 12 Feb 2012, 11:54 pm »
Wow!
+1
Great job, thanks for the pics.
praedet
« Reply #109 on: 13 Feb 2012, 12:05 am »
Thanks guys.  THere are things that I am not 100% happy with, but I want to listen to them before I start loosing my hearing, so I am going to have to be ok with them...
I think once the music is playing I won't see a single problem.
Anyway, so far I am happy since this is my first set of speakers I have ever built and my first time veneering...
NeilT
« Reply #110 on: 13 Feb 2012, 12:57 am »
This is true and your speaker looks incredible.
Very very nice.
Neil
SoCalWJS
« Reply #111 on: 13 Feb 2012, 01:09 am »
Very nice work! Finish 'em up and share more pictures. :thumb:
dBe
    • PI audio group, LLC
« Reply #112 on: 13 Feb 2012, 01:37 am »
Those look awesome, Ted.
Dave
praedet
« Reply #113 on: 13 Feb 2012, 02:35 am »
Thanks guys.  I definitely have put my PC to work helping me do the polishing on these guys...
eclein
« Reply #114 on: 13 Feb 2012, 03:10 am »
I've been following since the beginning and that looks 110% better then I ever though they would look..incredible job!!!!!!!!I give it 5 dancing sunglass guys!!  :dance: :dance: :dance: :dance: :dance:
HT cOz
« Reply #115 on: 13 Feb 2012, 05:03 am »
Wow very nice!  I wish my first set of speakers looked so good...  :thumb:
freerider
« Reply #116 on: 14 Feb 2012, 05:26 pm »
Amazing!  I bet those have some heft!
Danny Richie
« Reply #117 on: 14 Feb 2012, 05:36 pm »
I still have some of these flat packs if anyone is interested.
brandon w
« Reply #118 on: 18 Feb 2012, 12:57 am »
have you decided how you are going to attach the front baffles?  i have both of mine glued up, and am currently planning out how to cut the no-rez.  i have test fit my baffles and i'm going to need to do a lot to get them the match the cabinets perfectly.
praedet
« Reply #119 on: 18 Feb 2012, 03:06 am »
Honestly, I haven't and you are right about the baffles requiring some work for them to fit...
