Help Finding Record Cleaning Gadget
0 Members and 1 Guest are viewing this topic. Read 1146 times.
bside123
« on: 20 Aug 2010, 03:28 pm »
Greetings! I believe I saw a post somewhere 'round here about a record cleaning gadget that you clamp onto the LP that covers and protects the label, so you can go about wet cleaning and scrubbing the vinyl without getting the label wet. (Whew... long sentence!) I tried my best to search the archives but can't find it. Anybody got a clue? Thanks!
srb
Re: Help Finding Record Cleaning Gadget
« Reply #1 on: 20 Aug 2010, 04:52 pm »
Are you referring to the automotive dent puller?
http://www.audiocircle.com/index.php?topic=81756.0
starkiller
« Reply #2 on: 21 Aug 2010, 04:50 am »
The non DIY one is called the Groovmaster...bought one a bit back and really works well.  He usually sells them on Audiogon and ebay.
bside123
« Reply #3 on: 21 Aug 2010, 02:21 pm »
Thanks Starkiller & srb. Yup. Dats dem. :D
