0 Members and 1 Guest are viewing this topic. Read 15358 times.
Well, hopefully you would be using a high pass filter on the HT2's. It would be pretty hard to get a smooth blend otherwise, unless the sub was only operating below 30 Hz or so. But with a high pass filter, and with a crossover in the 60-80 Hz area, you would be taking a lot of the load off of the W18's. Would this really improve the midrange? There are more opinions than facts on that one. But if you ever make it back to Bethesda, you can help me lug my HT3 upstairs and at least see if you can hear much difference in the midrange with the HT2's running full range.
With an 80Hz crossover point in mind, what would you recommend setting the low pass filter to when using a pair of SongTowers or HT2-TL's and a subwoofer (or 2 or 3 or 4)?
Just get the SoundScape's and call it a day. Then you'll know you've got the best of the best.
You mention a "nasty bump" in the response of the right speaker. This indicates to me serious consideration might be given to the HT2-TL's. We have found transmission line designs quite a bit less sensitive to placement issues like this.Just a thought...- Jim
I'd hate to speculate on that as we just don't do sealed designs. So I've never really compared them.- Jim
I was assuming you would just use 4th order LR slopes and set both low and high pass to 80 Hz. But those things always take experimentation.
Great information to consider.....thanks Jim!Along those lines, my current speakers are a sealed design; would the TL design be less sensitive to placement than a sealed design? Perhaps also a factor is the fact that the bass drivers in my ADS are in a different position than the HT2-TL (ADS are closer to the floor than the HT2-TL)?
ratso - When you use a receiver as a processor to control the crossover frequency (say 80Hz) to the subwoofer, it creates a high pass filter for the main speakers and a low pass filter for the subwoofer. If it does this correctly, it will no longer send bass under 80Hz to the main speakers. It will send these frequencies to the subwoofer instead. It should create the appropriate filters for you.I hope this is what you were referring to.- Jim
If they are anything like sealed subwoofers, room gain will play a large roll with the design. A sealed design rolls off gently, but coupled with room gain you can get some serious amounts of extra depth down low. Again, this applies to subwoofers only, but might also apply to a sealed speaker...???
Thanks.Any thoughts on this, Dennis?
Not really. Thoughts come hard to me. But to be honest, I can't think of any reason why a TL would be less sensitive to your room mode than a sealed design, unless the sealed box tuning on your ADS's produced a peak in the 90-100 Hz. reason. And that's very unlikely given the size of your cabinets.
hey saturn i have a svs as-eq1 for my HT subs (and also a krk ergo which uses lyngdorf's roomperfect room correction for my 2 channel system) and i think either one would go a long way to fixing your bass response. i am really happy with both. the ONLY drawback i have is unless you have a way of adjusting for delay (like you are using an AVR that corrects for sub distance) then svs recommends using a device with delay like a behringer DCX 2496 along with the eq1. this would drive up the not exactly cheap cost of the eq1 of course. (not sure if this is true with the krk as i don't use it with subs, i just use it to tame the bass on my speakers for now.)
