Subwoofer or "bass module"?
0 Members and 1 Guest are viewing this topic. Read 9730 times.
Letitroll98
  • Too loud is just right
Re: Subwoofer or "bass module"?
« Reply #20 on: 12 Aug 2010, 11:08 pm »
Get rid of the WAF, keep the speakers.
Bass modules reduce WAF tremendously. Even if a 2 way bookshelf on a stand occupies the same space as a floorstander, WAF is still higher for the 2 way bookshelf.
roymail
  • Roy in TX
« Reply #21 on: 12 Aug 2010, 11:12 pm »
We've been married 41 years, that's not an option!  :D
roymail
  • Roy in TX
« Reply #22 on: 16 Aug 2010, 04:12 pm »
Thanks for the help, guys.
One thing I've thought about is how to hook up a 2-way monitor to a separate bass module and keep the impedance the same?  I'm guessing I'd have to change the 2-way crossover?  These are not my speakers.  It's a pic of what I'm talking about building.
eclein
« Reply #23 on: 16 Aug 2010, 04:26 pm »
That looks like a great project!!!
This may or may not be related but since I have gone to a 3-way speaker with a 12" woofer the bass is just so nice and deep, not boomy but nice deep consistent bass...I still use my 10" Polk sub but I think the bass module is a good idea once you work out the details of the build. I know if I ever upgrade my sub it will be at least 12"-15" inches, I've used my current setup with some JBL- L20T's bookshelf type monitors and a sub and it sounds nice but not as deep and detailed as having the 12" woofer in the mix. Good luck with the project!!
