Cabling length between VDA2 and passive pre
0 Members and 1 Guest are viewing this topic. Read 2471 times.
jk@home
« on: 9 Aug 2010, 11:44 am »
Dusty, how long can I go between a VDA2 and one of your passive preamps? I'm moving my rack, looking at a cable length of 1 to 1-1/2 meters for the above.
The passive's output cables should be as short as possible, correct?
Also, how close can the passive get to a SS amp (as in sitting above)? Best to stay away from amp tranny?
« Last Edit: 9 Aug 2010, 03:19 pm by jk@home »
CIAudio
Re: Cabling length between VDA2 and passive pre
« Reply #1 on: 9 Aug 2010, 04:25 pm »
2m cable length shouldn't be a problem, and yes it's best to keep cables between passive and amplifier as short as possible.
It is best not to stack components...you can try it to see if you pick up tranny noise.
rollo
  • Rollo Audio Consulting -
« Reply #2 on: 9 Aug 2010, 05:14 pm »
  Magnetic fields dissapate with distance. About 4ft will do. Experiment as suggested. 1.5 meters should be fine.
charles
jk@home
« Reply #3 on: 9 Aug 2010, 05:36 pm »
