Paradisea 3 Problem
0 Members and 1 Guest are viewing this topic. Read 1619 times.
greg7
Paradisea 3 Problem
« on: 4 Aug 2010, 11:06 am »
On songs with lots of bass, my Paradisea 3 clips or has a form of distortion. I've only noted it on 2-3 songs thus far but it must be something wrong. I've tried 4 different tubes to make sure it isn't the tube. What could the problem be and do I need to send it in for repair? Is it possibly just microphonics with the tubes that can be solved with tube dampers? Could it be the digital cable? The Paradisea 3 is a non-oversampling DAC so is it something associated with non-oversampling? I used to own a 47 Labs Shigaraki and I never had this problem with it, though.
Listens2tubes
Re: Paradisea 3 Problem
« Reply #1 on: 6 Aug 2010, 02:11 am »
Got bubble wrap? The large bubble type will be best. Slip some under to isolate the DAC. See if that helps. 8)
raindance
« Reply #2 on: 13 Aug 2010, 03:12 pm »
Some more details on your system might be helpful if you want a remote diagnosis.
