tube dampener for 12sc7 size
0 Members and 1 Guest are viewing this topic. Read 2282 times.
drphoto
« on: 2 Aug 2010, 12:54 am »
Hey, I'm not sure from looking at the product page if you have a tube dampener for the 12SC7 type tube. Same size as the 12SN7, which is a little more common.
Is there one? Even w/ tenderfeet under the pre I still think I'm getting some microphonic crud from these phono tubes.
Herbie
    • Herbie's Audio Lab
Re: tube dampener for 12sc7 size
« Reply #1 on: 2 Aug 2010, 02:46 pm »
Hi. If your 12SC7 is a straight-sided glass bottle tube, you'll use a size "30" damping instrument. If the 12SC7 is a metal-shell tube, you'll use a size "25" damping instrument (if bottle-shaped, size "40").
Though any of Herbie's tube damping instruments would be appropriate for this tube, I recommend considering UltraSonic Rx or UltraSonic SS for the 12SC7.
Herbie's Audio Lab
« Last Edit: 29 Jul 2011, 03:17 am by Herbie »
