0 Members and 1 Guest are viewing this topic. Read 8454 times.
The downstairs inner wall is a possibility if this doens't work, but we're talking an L shaped room here, with the inner wall being 28 feet long with only 10 feet of length from side inner wall to side outer wall, with the speakers out at least 2 feet, we'd be very near field, and from what I've read on Brian's Desinger's corner, there's a problem with doing this. His speakers perform best when they have side near walls to reflect the sound. Were I to place them inner wall they'd be a good 8 feet from the left "ajoining" wall and a good 14 feet from the right side ajoining wall. Don't know what that would do to the sound, but from what I've read it might not be good.
There is no problem placing VMPS speakers on the long wall, in fact that is exactly how I have my 626Rs set up currently. While I have a room that is 19 x 30, my sweet spot is only about 7'-8' from the speakers
If you have a choice of setup locations, use the short wall of the room as the speaker wall and place them 12" to 16" from the back wall and 18" or more from the side walls.
Hopefully the 12 - 16" from back wall is also flexible, as my placement, using the short wall will have them out 5 feet from the back wall (measured to rear of speaker).
Recently we used the 626R several feet into the room on very light stands (hadn't been filled with sand yet) and they were rather bass shy, so this might work to your advantage. Now in reality, bass shyness at the listening position does not mean that the speaker is not putting out the same bass energy, it just means that the energy is not working its best bass at the listening position.
Interesting...if that's the case, perhaps I don't need to install the bass traps I had in mind. I could be good to go as is
Speaking of bass traps (or acoustic traps in general), has anyone used these guys: http://www.realtraps.com/
Are you going to do any room analyses before and after?
Actually, if I recall correctly, Brian said that spikes on the bottom of speaker standsactually make the speakers transfer their base power *more* effectively to the floor, not less.Causing the bass traveling through the floor to get to the listener faster than the bassgoing through the air (sound travels faster through denser materials), which can causeproblems with a muddying of the bass.So spikes on the speaker stands wouldn't help with reducing the bass that neighborsmight hear in an apartment building. On the other hand, it's always been my understanding that the reason one puts spikes on a speaker stand is to isolate the speakers from the floor in the sense that vibrations in the room, such as from someone walking around the room while music is playing, will not reach the speaker cabinets themselves and cause a reduction in the purity and clarity of the sound. John Casler: Do I have that about right?...
But one also sees spikes used on the better stereo equipment racks often. In this case, it's to isolatethe equipment from the room (any vibrations, in particular), rather than connect it.
