Inexpensive speakers for use w/ low powered amps
0 Members and 1 Guest are viewing this topic. Read 14617 times.
lcrim
« on: 30 Jul 2010, 02:43 pm »
Inexpensive speakers are defined as less than $100 per pair, ready to use.  Low powered amp is defined as 5 real watts or less.
I still have an original Miniwatt @ ~2.5 watts per, it is fairly easy to find a Tripath unit for roughly the same approx. cost.  I'm sure there are other possibilities-el84 consoles from organs etc.  I have a number of older DVD players for a digital source that sound decent, the stumbling block, IME continues to be a pair of speakers that are efficient, sound nice and that have a "presentable" (esthetics can be very individual) appearance.
I would like your suggestions.  I think this is the correct circle.
HT cOz
Re: Inexpensive speakers for use w/ low powered amps
« Reply #1 on: 31 Jul 2010, 04:40 am »
Wow that is a tough budget. I think I would look for klipsch in craigs list. Someone will sell a pair without knowing the pedigree.
Construct
« Reply #2 on: 31 Jul 2010, 04:41 am »
Since Klipsch was mentioned:  Polk audio Monitor 5's.  VERY smooth and transparent.  Total steal for $80-$150/pr. Also look into vintage infinity.  Boston acoustics hd-9's.
dvenardos
« Reply #3 on: 31 Jul 2010, 07:49 pm »
Yeah, cheap and high efficiency don't usually go hand in hand.
« Reply #5 on: 3 Aug 2010, 09:28 pm »
Yes, I thought about the Insignia too, but at 90 dB/w/m and 8 ohms not the greatest potential for a 2 - 5 watt amp.
For low power the Hawthorne Audio Silver Iris coaxial drivers are hard to beat (highly efficient, nearly full range, but designed to be used in open baffle).  For $400/pair Darrel will sell you a pair, with baffles:
http://hawthorneaudio.com/index.html
Scott F.
« Reply #6 on: 3 Aug 2010, 09:49 pm »
Larry,
That's one tall order. I'm not sure you can get there short of building a pair of Fostex full rangers (and the small Fostex at that).
If you can up your budget a bit, I can attest to the JBL 4410 Studio Monitors
They sit at about 91db and have a fairly benign impedance peak of 27 ohms at around 60Hz. Couple that to the fact that they sound really flippin' good and you could have a darned nice sounding system. Sure, you won't rock the house with 5 watts and 91db speakers but what you will get is far better than you might think. Oh, I personally think the 4410's sound significant;y better than the L100s and their cousins...but that's just me.
These can be found on Craigslist and eBay in the $300-$400 range.
I won't ever part with mine.  :thumb:
eclein
« Reply #7 on: 3 Aug 2010, 10:02 pm »
I love my JBL 4312A's...best $50 I ever spent in my LIFE!!!!! There are incredible used items out there, mine were found on CL.
« Reply #8 on: 3 Aug 2010, 10:39 pm »
I found a pair of Polk Monitor 7's for $5.00
at a local good will store not sure about
the eff. I don't think Polk's were all that eff.
Found these specs later
Electrical
Overall Frequency Response 25Hz - 25kHz
Lower -3dB Limit 40Hz
Upper -3dB Limit 23kHz
Nominal Impedance 8 ohms
Recommended Amplifier Power 20-150 w/channel
Efficiency 89 dB
Also a pair of Monitor 10's I paid $125.00
« Last Edit: 4 Aug 2010, 12:47 am by pumpkinman »
MLS
« Reply #9 on: 3 Aug 2010, 10:54 pm »
Those Monitor 7 look great.  $5 is a steal.  They are a very good speaker and are IIRC low 90's db efficient.
enjoy those.
MLS
eclein
« Reply #10 on: 3 Aug 2010, 11:02 pm »
Nice find pumpkinman!!! :thumb: :thumb:
HT cOz
« Reply #11 on: 5 Aug 2010, 04:41 pm »
I think I would up my budget $100 bucks and jump on something like this http://www.vanns.com/shop/servlet/item/clearance/542598495/klipsch-rf52-black-single-speaker
srb
« Reply #12 on: 5 Aug 2010, 05:00 pm »
That's a single speaker and would be $429/pair.
Construct
« Reply #13 on: 5 Aug 2010, 05:02 pm »
Electrical
Efficiency 89 dB
Yep, good call!  They are the bigger brothers of the monitor 5's I mentioned.  You got them "stupid cheap".  The good thing is that they are terrific stock, and a few buck will upgrade them greatly.  NICE speakers!
HT cOz
« Reply #14 on: 5 Aug 2010, 06:13 pm »
Mono anyone?   :lol: :lol: :lol:
Sorry
srb
« Reply #15 on: 5 Aug 2010, 06:36 pm »
Sorry
Yes!  I have a mono system as my "Super Shower Radio" bathroom system (Yamaha MSP3 powered monitor + Airport Express).  I have absolutely no imaging, soundstage, lobing or cancellation anomalies!
Construct
« Reply #16 on: 5 Aug 2010, 06:40 pm »
Tivoli radios are a nice monaural system.
Borisbadenov
« Reply #17 on: 21 Apr 2014, 04:58 am »
To get the most out of your amp you will need the most efficient speakers and polk is far from that.
89-90 db is very low.
Try VINTAGE sounddynamics if you can find any or vintage klipsch.
Keep in mind klipsch are measured at 30 feet not 3.
They are EXTREMELY loud.
I can't say they are easy to listen to.
2.5 watts is like headphone volume.
You can get a good used receiver for 20 bucks and you won't hear much difference from others if you use the eq's.
