E10 Gasoline: What do you think of it?
0 Members and 1 Guest are viewing this topic. Read 2116 times.
Niteshade
    • Niteshade Audio
« on: 26 Jul 2010, 11:29 am »
My vehicles seem to work fine on it. I'm wondering if it's necessary to add anything like dry gas or fuel injector cleaner to it.
I couldn't believe it! My old Caddy got 24mpg on the Thruway last week! Not bad for a V8.
twitch54
Re: E10 Gasoline: What do you think of it?
« Reply #1 on: 26 Jul 2010, 01:47 pm »
OMG, the LAST thing you want to add is MORE alcohol.
JCS
« Reply #2 on: 26 Jul 2010, 03:32 pm »
I have NO fondness for E10.  Every time they reformulate gasoline, my milage seems to drop.  In hot, humid summer weather my 2001 Echo used to get as much as 53 mpg.  It has dropped incrementally with gas reformulations so that I'm lucky to get 47 mpg.
And pity the poor folks w/ older small engine equipment.  The E10 seems to burn hotter resulting in engine failures.
Then there is the question of energy balance and economics.  As an analytical chemist, I'm not convinced that the ethanol (made from corn) displaces any oil usage.  Ethanol made from sugar cane is a different matter... but that's a story for another day.
Cheers,  Jim
