0 Members and 1 Guest are viewing this topic. Read 11309 times.
TC Sounds drivers and DSP amplification. Stay tuned...
If the box is made right the Tc sounds are monsters. I priced out a 12 and 15" driver for a project and the drivers alone are $400-$500 each. Nice xmax and power handling to say the least.
If the drivers cost that much, I strongly looking at the Rythmik servo subs. I have them and am very happy.
Have you ever seen a Klippel test of those drivers without a servo attached?
Why would you ever run a servo based driver without the servo?Best,Ed
The Klippel system is the industry standard for driver testing and design. It would be used to test the driver's capabilities before it's installed in a subwoofer of any type (sealed,TL,servo,ported,etc).
Thanks Rick. Yes, I am aware that it is a test of drivers without enclosures but the servo mechanism is part of the electronics of the driver, not the cabinet alignment. Does the Klipple test require that the driver be driven by a specific amp that would preclude the use of a servo amp or is it simply a measuring tool. Sorry if this is too basic a question, also apologize for the off topic nature of this question. Please feel free to remove the post if necessary.Best,Ed
No problem - I encourage open discussion here and I think it benefits everyone. Regardless of whether a servo is used or not the woofers still share common traits such as distortion created by the motor or suspension. So even before the servo is applied you have to consider these issues. As far as incorporating a servo within a Klippel test I don't know - probably not is my guess.
To phrase it another way, would you buy an amplifier that relied on enormous amounts of negative feedback in order to make it listenable? Perhaps a better approach is to design a driver that inherently is more linear over its' operating range? Klippel measurements are used (by manufacturers) to design better performing drivers. That said, who has seen Klippel measurements for the Rythmik drivers?
Very well said.
I don't think so, I believe a more appropriate question would be:To phrase it another way, would you buy an amplifier that relied on enormous amounts of negative feedback in order to make it listenable accurate?In this instance the answer is a definitive YES!Best,Ed
Isn't the end result (sound) really what matters? A short block engine is great but without the heads it's useless. Or the nicest speaker cabinets that you can build are great but without the drivers, wire and crossover they don't sound good. Servo-Maybe the driver doesn't measure as well as others but with the servo it may be better. Isn't that what matters? The whole package.
