0 Members and 1 Guest are viewing this topic. Read 15940 times.
you are welcome... nah, i'm just a lousy photographer and my camera is of playskool quality... lol... all of us who have bought jim's speakers went through what you are going through now... as far as "looks natural" goes... not to me, but i'm biased there... i had to hunt for the grills to put them on to take the pics... i like to see the baffle and the drivers... i never use the grills... plus i paid for that mahogany baffle... yea... there's no labor upcharge... the only cost is the materials... iirc, the veneer was around 650... the solid mahogany baffles were 150.. mahogany plinth trim another 150... so a bit less than 10 franklins, total...
I understand about the grills. I'm not sure if I will have them on or off, but want to make it work best either way.
You're not going to want to listen with grills on!!
pstrisik........there is no brightness with the raal tweeter,provided your stereo is up to it.
Yes, that is the primary reason I am upgrading and choosing Salks with RT!
So where are you leaning Peter? My room is 13.5 x 19 x 8 and the SS8's work, so did the HT2's and HT3's.
Given that you've now had both models (though I don't recall if your HT2-TLs had the RAAL), how does all of this reasoning sound to you (putting aside if you can your feelings about about subs and EQ! )?.....Peter
........yea... there's no labor upcharge... the only cost is the materials... iirc, the veneer was around 650... the solid mahogany baffles were 150.. mahogany plinth trim another 150... so a bit less than 10 franklins, total...
