FS - Definitive Technology Mythos Five Speakers - pair
0 Members and 1 Guest are viewing this topic. Read 1068 times.
dee1949_0
 - Pair of Silver Definitive Technology Mythos Five Speakers in excellent condition.
 - For local pick up in Washington DC 20017 - Cash on pick up - $600.00 for pair
 - These cost $1200.00 a pair and you can add more at $600.00 each to complete your HT setup.
 - They are still a current model.
http://www.crutchfield.com/s_735MYTH5/Definitive-Technology-Mythos-Five.html?tp=185
 - Gorgeous aircraft-grade aluminum cabinet
The slender Mythos Five cabinet is made of silver hand-polished aluminum, and rests on a tempered glass base to maintain rigidity and stability. Every aspect of the enclosure has been engineered for optimum sound quality. For example, the non-resonant PolyStone front baffle holds all seven drivers securely in place while fighting distortion-causing vibrations. Definitive's goal is simple: you should be hearing the drivers, not the enclosure.
Details:
    * frequency response 40-30,000 Hz
    * sensitivity 89 dB
    * 8-ohm impedance
    * handles up to 200 watts
    * one 1" pure aluminum dome tweeter
    * two 3-1/2" midrange drivers
    * two 3-1/2" bass drivers
    * two 3-1/2" bass radiators
    * 5-way binding posts
    * aircraft grade extruded aluminum cabinet and tempered glass base
    * gloss silver finish
    * 8-1/8"W (glass Base) x 40-1/8"H x 8"D (glass Base) w/spikes
.....you can complete the Mythos system with additional speakers below: unfortunately Mythos spkrs are NOT discounted.
http://www.definitivetech.com/Products/FloorStand/Default.aspx
« Last Edit: 29 Jul 2010, 12:27 am by dee1949_0 »
dee1949_0
Re: FS - Definitive Technology Mythos Five Speakers - pair
« Reply #1 on: 16 Oct 2010, 05:11 am »
....reduced - $575.00 . Local Pickup in Washington DC
