0 Members and 1 Guest are viewing this topic. Read 14785 times.
Hi Richard,Not trying to make your decision more difficult but there are great MTM designs out there. Here is a MTM TL loaded design I built for my sister, it is outstanding:They are GR Research N3s. You can find more info in the GR Research circle here on AC. Here is a link to the N3 webpage:http://www.gr-research.com/index.asp?PageAction=VIEWPROD&ProdID=151Best,Ed
It looks like I need to be looking at some other options. I agree the crossover is pretty high and at a critical frequency. I've start looking at two other designs that are 2-way towers.I noticed that there are two version of a tower kit at Madisound that look very much the same, but from different people and both look very good. One is the zaph zrt revelator 2-way tower and the other is the scan speak rediscovery. Both use scan speak drivers and both are tower speakers. The Zaph version is more expensive and both use different scan-speak tweeters.Talk about making this decision more confusing!!! They both look like great speakers but how do they compare??? Zaph has alot of interesting design notes on there web site and even shows a 2.5 version with two med woofs instead of one and also show a sealed design with a similar response curve.Does any one know how these kits compare? HELP! Richard
I am looking to build the Zaph za5.5tt but can't find any reviews or information on what they sound like. It is a mmtmm configuration and looks like a high end speaker, but does it sound like a high end speaker and how does it compare to other speakers? I have two hsu subs that I want to use with them. It looks like they would be good with a sub as they are somewhat shy in the bass region.Has anyone built these units? They are offered as a kit at the Madisound site.thanksRichard
I think the question is why have so many drivers and what does it do to the accoustic center? CheersRobert
Hi, http://www.zaphaudio.com/ZA5/, discussed in fair detail, rgds, sreten.
Ok so its a 2.5 way with multiple drivers. 89db efficient and dips to 2-3 ohms in some places.I understand that using multiple drivers lowers the load on each driver and lessens distortion, but I don't think it is worth it given the impedance dips and complexity when compared to a MTM in a good tuned enclosure.I really value an easy load as I can then use any amp with the right output for my given room and speaker sensitivity.Nothing more than my opion based on prior speakers that might be completely irrevelant because they are not the speaker in question.
This system is 89 sensitive anechoic with 1 watt input and a solid 8 ohm nominalimpedance, drooping to about 5 ohms for a small range between 2 and 3 kHz.
Hi,If you don't like the look of them fair enough but your missing the point.The MMTMM and MTMMM versions by definition are 8 ohm versus 4 ohmfor any MTM or TMM version using the same driver, and will play louder, if that is what is needed for larger rooms.The driver is specifically optimised for good midrange over bass performance,and as such the designs are specifically intended to be used with subwoofers.rgds, sreten.No subs ? then perhaps other designs are best looked at.
The cool thing about a MMTMM is the control over the lobing. I wouldn't say it minimizes the lobing, it just spreads it over a much wider range of frequencies. The vertical off axis is beginning to roll off at 200 Hz already. In room, it means floor bounce is minimized. I've got data showing this, including in-room and vertical polar plots. What it sounds like is a level of smoothness in the midbass and lower midrange unlike other types of speakers. Not to mention a system with that manylow distortion drivers sounds completely effortless.
