VMPS LARGER SUB Summertime Close Out Special and Report
0 Members and 1 Guest are viewing this topic. Read 1313 times.
John Casler
The VMPS LARGER SUB Summertime Close Out Special and Report
Over the last year Brian has posted regarding the changes to the Woofer/Drivers in the LARGER Subwoofer.
Due to raw material (Woven Carbon Fiber) availability, he has had to move on to another 12" Megawoofer.  Of course Brian didn't just find a replacement, he has a better 12" and also a matching 15" driver.
Not too long ago B, posted
"The WCF 12" cones are no more, victim of the worldwide carbon fiber shortage.  We and the Misco people engineered a new mica filled 12" polycone and a motor with a flat spider with 3mm additional Xmax and 4Hz lower Fs."
This 12" driver also has a 80 oz magnet.
This of course means that the New MegaWoofer makes you the beneficiary of that shortage.
B, also wrote:
Our old 15" "Megawoofer" of the past six years has been a 75oz magnet polycone.  The new Eminence-sourced Kevlar reinforced paper cone driver with the 100 oz motor and 20Hz Fs. The cone is extremely stiff   It has better Xmax (15mm) than the old poly 15" "Mega".
12" MegaWoofer:
  • Mica filled Polycone driver
    Flat Spider
    80oz Magnet
    3mm additional Xmax
    4 Hz lower
15" MegaWoofer
  • Kevlar Reinforced Paper Cone
    100oz Magnet
    15mm Xmax
    20Hz Fs
Here is a picture of the new look (thanks to CONSTRUCT for the photo)
Both of these MegaWoofer drivers are the "little brothers" to the ULTRA-MegaWoofers used in the VLA and VSS at $225 for the 12" and $350 for the 15".  These two UltraMW woofers are also available as upgrades but come as the "stock" drivers only in the VLA and the VSS subs.
The bad news is that these drivers are also more expensive and the price of the upgrade will need to be adjusted upward to reflect this increase.  Although trying to keep this down, we are looking at having to charge at least $200 for the new MegaWoofer upgrade instead of the current $140.
So before we increase the price we wanted to allow anyone thinking of going LARGER to do so now.  The increase will go into effect August 31st.
So gentlemen get your LARGERS now!
Base Price LARGER = $699
Current MegaWoofer Upgrade = $140
$839 plus shipping
After August 31st $900 plus shipping.
Also look below for the LARGERjr special :scratch:
Is that an OXYMORON like JUMBOshrimp :scratch:
