0 Members and 1 Guest are viewing this topic. Read 14638 times.
I'm using Lundahl 1544A's for phase splitting in front of my McIntosh 275 and the improvement over running it single ended with the internal phase splitting is quite substantial IMO.BTW, John that is a cool looking 2A3 PP, would love to hear it. Your design?
Mike, what improvements have you noticed over the tube phase splitters?
It has dual feedback loops, one for each phase. The output transformers have a dedicated feedback winding, so it's not tied to the speaker outputs, which are single ended as the negative is tied to ground. The block diagram in the manual shows the unbalanced inputs going through a level control and then into the "unity inverting amp" which is just a grounded cathode stage to invert the phase. After that it's input amp > driver amp > cathode follower > output amp, 2 of each stage per channel. The feedback loops connect back to the input amps.
Isn't the tube phase splitter more commonly called the driver? Or is the driver something else entirely?
