Cost of Your System
0 Members and 1 Guest are viewing this topic. Read 9504 times.
Construct
Re: Cost of Your System
« Reply #40 on: 16 Jul 2010, 04:33 pm »
Ive always loved their Reference speakers......even of 10-15 years ago.
I had some 105.2 and 103.3 until 4 years ago.  I had some very expensive reference amps and cd player driving them.  Both were flat, uncolored and extremely revealing.  There was no glaring flaw to point at.  I sold them due to a pending move (I figured they could get ruined in the move)  but would still have them if I hadn't.  They compare favorably to reference dynamics now. I especially like the full range ability of the 105.2, and the superb bass definition.
HsvHeelFan
« Reply #41 on: 16 Jul 2010, 04:50 pm »
The KEF Q70s are rated at 35hz on the bottom end.  They use the Uni-Q tweeter-midrange coaxial setup and a ported upper bass driver and a ported lower bass driver. The midrange and bass drivers are all 6 1/2 inch.
My 4B-ST goes to the Velodyne sub and it handles everything below 80 hz while the KEF's handle everything above 80 hz.
It works well for my system.
HsvHeelFan
Construct
« Reply #42 on: 16 Jul 2010, 05:08 pm »
HsvHeelFan
I have no direct experience with the Q70, but the older KEF that I had were rated very conservatively.  KEF used to rate mine 50-20khz +/- 2db.  The nominal response was actually 38hz-22khz +/- 3db- what is considered a "flat"  rating now.  They were strong to the low 30's and beyond audibility.  That was quite a feat for over 30 years ago.  They gave you performance more associated with 1990's "flat/extended range"  than 70's or 80's. I was surprised how much better they sounded with better electronics.  I heard them with a pioneer int amp- not bad.  But moving up to musical fidelity, Naim and others---they got better as a high end speaker should.
VOLKS
« Reply #43 on: 16 Jul 2010, 05:16 pm »
Kef and Bryston are a great match.
Construct
« Reply #44 on: 16 Jul 2010, 05:17 pm »
I wish I'd had a 3bst or 4bst.  I prefer Bryston to Naim, LINN and Musical Fidelity.
vegasdave
« Reply #45 on: 16 Jul 2010, 08:23 pm »
Current set up includes ...
JBL 1400 Project Array's with Bryston 7B's, BP 25 and BCD1
Purchased between 2008 - 2010
Cost $20,000
Even though your system isn't cheap in absolute terms, it's great bang for the buck in the context of high end audio.
vegasdave
« Reply #46 on: 16 Jul 2010, 08:24 pm »
What do you have now? A 2B?
vegasdave
« Reply #47 on: 16 Jul 2010, 08:24 pm »
Which brand of amps may I ask?
