0 Members and 1 Guest are viewing this topic. Read 14030 times.
Another nod in favor of the 12SN7 is that they are far cheaper NOS than the 6SN7. A nod against it is that it is no longer in production.
I honestly would not worry about the prices of 6SN7's. Most are very reasonable. Just leave the ridiculously priced ones alone. Good used vintage 6SN7's are $5.00 to $15.00 each. One of my favorite new 6SN7's in made by Tung Sol. Another, believe it or not is the Sino 6SN7.
Hi Blair,So which brand do you use?Also, is the buffer standard fair on the Beacon3 or how much minus the buffer? Also, so you are using 4 tubes? three in parallel, and this split gain stage?Ray Bronk
Are you ever going to make a fully balanced pre?
I like the idea of using XLR sockets because they are rugged.If I did make one, it would be a true balanced input that uses transformers. When will this happen? As soon as someone asks for one. I would use transformers on the input to keep it truly balanced up to the sources.
Actually, I do not have a favorite brand of tubes, either for power or small signal applications. Every manufacturer has a different characteristic about their product, even if it has the same part number. This fact is what makes tube rolling so much fun!What to stay away from: JJ/Tesla GZ34's. If you like your amp/preamp...STAY AWAY!My buffer mode is an add on and can be implamented with the Beacon One and up. It is an active buffer with no voltage gain. It is used to match a source up with an amplifier (which a pre w/ voltage gain does as well). Beacon Three: All three tubes can be used in parallel or one can be used as an isolated gain stage. There is also the possibility of putting tone controls in series between the gain and driver stage.
Unless otherwise specified, a Beacon Three can have one of the following configurations:1) An isolated gain stage + two-tube driver stage2) All three tubes in parallel (no isolated driver stage)The upgraded tube rectified power supply will provide these benefits:1) Additional current available to the audio circuit2) Additional filtering stages3) Another user-replaceable componentThe idea is to get the tube rectifier to "feel" what is going on, much like they do in a tube amplifier. Think of it as an increase in tactile sensation. I like the 5U4 or 5AR4. They're interchangeable in this circuit to make tube rolling more inviting.My standard power supply isolates the audio circuit from the power supply as much as possible. It works great as well, by providing exceptionally pure DC for 99% quiet backdrops.
