0 Members and 1 Guest are viewing this topic. Read 86489 times.
I was at the shootout and am the owner of the WFS used at the shootout. Steve Garland in fact thought the WFS OK but Steve has definite views on DAC sound and preferred his DAC and a heavily tweaked pcm1704 DAC describing the sound as REAL. Having heard both DAC's that is my view as well - the WFS sounded HI Fi ish but the Killer DAC sounded REAL. Of course my and Steve's view is in no any more valid than 6 Moons professional reviewers. I will also tell you a professional reviewer was also at he shootout and he had exactly the same view as Steve. Also I only know of one professional review of the WFS - to really get a consensus we need quite a few more. Bottom line here is there is no absolutes and many varied and conflicting views abound. Just because one professional reviewer likes a product does not mean another will nor even that you will like it. From my experience it would be very wise not to base purchase decisions solely on reviews - seek the product out and listen to it.ThanksBill
PS Audio trasnport via I2S is a formidable transport. How does USB stack up compared to that?
When I had the PS Audio DAC (PWD) the USB performance was only so-so, and I expected that. I never really believed computer audio could sound really good. With W4S DAC2 my Mac Mini does a great job. Sometimes I can't tell if my source is PWT or Mac. I am sure there is some difference (I believe so) but it is very subtle.
How's come?That's interesting. You kept the Perfectwave Transport but got rid of its matching sister product, the PWD.
I replaced PWD because I was running out of room in media cabinet and I was not happy with its USB performance. The W4S DAC2 has a smaller footprint physically as well as economically, but big on performance. I kept the PWT because I really like it as a transport. DAC2 was an ideal choice for me because I can still keep PWT with its I2S connection and also have a musical computer audio system.So far the listening experience has been very enjoyable.For example yesterday I loved listening to McCoy Tyner's New York Reunion from HDtracks (especially the track Recorda me with its drums passage sounding so nice) on my Mac Mini as well loved listening to Christian McBride redbook CD through my PWT-I2S. Best of both worlds for me:) If only PWT played SA-CDs...!
Unfortunately audiophiles in my area have no hopes of hearing any of these products unless we buy one or somehow get to hear one through getting ahold of a demo unit somehow. So in my case reviews have to be a major source of info. The search for a dAC has been the most frustrating part of my recent system upgrade. There are many new DAC's on the market and the confusion over USB inputs/ what data rates will it play etc. makes for a hard decision for me as I have decided to go the computer route(mac mini) There is also the NOS vs Delta Sigma vs multi bit debate to add to the mix. Local audio stores carry virtually nothing in high end gear anymore as the market has shifted almost entirely to HT. When it comes to reviews I agree that 1 review from a magazine is not a consensus but I also can look at the reviewers history and get a feel for what his biases and preferences are. With owners reviews they have payed for it so they are not usually objective. In your shootout there is a bias built into the review due to the relationship of the builders to their products and the listeners to the builders. There are also a lot of amateur reviews out there that really are outrageous. One I read proclaimed how good a DAC was and then the reviewer went on to say he had tinnitus so bad that it took a level of 85 DB to drown it out. So professional reviewers with a track record are for me a better source of info. than user reviews. I don't have an unlimited budget and I need this to be a long term purchase. I need a product that has a customer service department and a warranty behind it. I also want to experiment with high res. music files so that is an important consideration. Everyone has their own listening preferences. When I hear terms like liquid and fluid used to describe music it sounds like all the rough edges have been removed. In my experience and preference these details are very important to me. To others maybe not.
I'm using the PW transport with W4S DAC1 through I2S. Great combo.
According to a report on CA, Rick Cullen is developing a USB-I2S async interface specifically for the PWD.Do you think the DAC 2 sounds better than the PWD?
You guys have to remember that the Tranquility DAC is a tweaked thang. Eric listened to every little part in it. Not so with the Wyred for Sound...
Imagine how good the ESS DAC chip could sound if they spent that much time on it! I am sure the ESS DAC they used to reference against was not "totally tweaked". Maybe Eric can chime in and tell us how many hours they spent optimizing the ESS eval board/Buffalo board? they were using and exactly what they did to it. I would like to know.
I have zero idea Rick but what I can tell you is this. They built an ESS Saber DAC and found an issue in the upper midrange that did not sound quite right and it did not matter what they did they could not get rid of it. Because of that hey decided against it. The designer at Audio GD found exactly the same issue - it had a slight issue in the upper midrange they could not get rid of - they described it as making voices sound younger but the way I would describe it is a sibilance control issue. And once you cotton onto it depending on the material it can be quite noticeable. At the recent shootout I attended I also listened to a modded oppo and I can say for sure the issue was definitely reduced - but I don't think it was eliminated. Maybe with the statement mods you suggest it can be entirely eliminated - I don't know. But what I can say is a NOS statement DAC like you suggest was also present fully tricked out with stuff like Duelund capacitors and it sounded fantastic and easily beat the modded oppo. Interestingly the Tranquility when compared to this DAC was comparable when fed from a non optimized computer source - not quite there but close. When optimized we will see exactly what level it reaches. If your modded WFS can beat it IMHO you will really have something - and I may even get my WFS modded - but man is the Tranquility great bang for the buck.ThanksBill
With all due respect, I know it's a great product and a great value but there's an obvious drawback to something like the Tranquility for a lot of us. All it has is a USB slot on it. It doesn't handle any other kinds of digital sources. Same goes for the $2500 Ayre QB-9. I'm sure these are awesome products at their price points but for me personally, I'd never buy just a USB only based DAC. YMMV, IMHO, and all that.
Sure. I only use the USB input so it is no problem for me.ThanksBill
Hello hmen, Great to hear that you are also using PWT with WFS DAC. Isn't it amazing? Did you have PWD before DAC-1?Can you shed some light on the performance of your DAC? Have you noticed any sibilance or glare as stated here?I absolutely don't find anything wrong with it.
