0 Members and 1 Guest are viewing this topic. Read 86440 times.
"detailed, analytical and dark"...This is very rare combination. usually if the dac is detail and analytical, it would be lean toward bright side of things. Sometime the voltage+impedance for each dac is difference, so when downstream is picky about these, there would be big difference in A/B test, yet not necessarily from the actual quality of the Dacs. Not to mention the preamp portion in the equation.
If your friend Mike had already gotten his dac and preamp in great synergy, and A/B show they are this close, then it's no small feat for WFS dac. With enough time and resource(cabling,power, heck...change the amp), it'd could be better. Not to mention burning it in.
Also, difference in overall speakers choice plays a major role as well I believe. Is the system high eff FR, planar, OB, hungry or higheff dynamic (2/3/4.../8 ways),back horn loaded, omni directional......? Some setup favor certain range of freqs, and have very diff strength and weakness (timbre, attacks, transiency) Would love to get some more juicy detail about downstream to get a better picture of things.
Of course! Hes using his own ML1...That gives us some idea. Thanks!
As I said the sound is a bit unusual and takes a little getting used to. We thought the quality was equally as good as the 1704's but since it's a bit unusual that may have simply been the novelty of it. That's why Mike wants to keep them longer - to see what eventuates.
P.S. Also I don't think you'd want to change any volume in computer. Don't care whatever transport software (itune/foobar/iriver/kmplayer...), Bit perfect means no digital preamp filter, and use bypass helper whever possible (ASIO/WASAPI/itune_setting).
Also, in the end, "bit perfect" may be something desirable, but it neither guarantees nor prevents GREAT sound quality.
Nice synopsis. There are few reviews for the DAC2 so far. A couple of questions:1) How much break in did the Wyred DAC2 have? Most, including EJ, recommend 200 hrs, with some cycling so caps cool down and recharge a few times.
2) Did you adjust/set the USB output for the amp or preamp input (gain)? Some have reported that the default max is too high for their systems (thereby possibly robbing the combo of dynamics or optimum s/n). I know that parameter can have major impact on dynamics, etc. Srajan has a nice tip or two on his preview http://www.6moons.com/audioreviews/wyred4/dac_2.html
That's true. But for someone whos looking at a DAC like W4S, meaning they would want to at least try out some high res recording. So why would anyone wants to use a digital software based volume. That defeat the purpose of having high res source.
From the way you sound, you obviously have not actually tried decent computer digital volume control vs. decent outboard preamp/volume control. Also, in the end, "bit perfect" may be something desirable, but it neither guarantees nor prevents GREAT sound quality.
That's very helpful. Thanks. At one point I was thinking of doing the Audio-gd reference one , w/ their 8x1704. But felt that I should get something more modern design if going for high res.
I would wait until I report on a direct comparison with the Tranquility. The word from the designer is it is very close to the ESS dac in bass and detail (but the EES still has the edge) but is much more musical and fluid. He hopes the high res dac he is currently working on will fix that and still retain the musicality and fluidity. We will find out.ThanksBill
So the Tranquility is using 1704(UK) for sure? I thought nobody know whats inside...
The Tranquility+mini is quite something by what I read at other post. I still cannot understand what Eric meant that his Dac has no oscillator. I mean, there's got to be a clock somewhere somehow. Right
I see many people are using it with good result, but there are zero professional review, and not posting any of the spec doesn't help either. I mean I can understand trade secret and all, but if someone wants to know about the dac for some nefarious reason, all they need to do is buy one. spec, chips, ohm.....I fail to see how these info can benefit competitors. There are tons of DAC out there using 1704, not like they sound the same.As a programmer, I can swallow a $1300 usb only dac. I can even give in to get mini. But people like us wants to at least know abit more whats in the DAC as well just for our peace of mind.Detail....16/44 is hard to beat a new ESS 32bits w/ 130db dynamic given both are good implementations. But musicality/fluidity....I mean how much are we talking about here % wise. Coz even for purist, Tran-Dac is asking alot of compromise here. Out of all the words audiophile writers use, musicality is one I really watch out for. Everything else I understand. But if a DAC has everything else right (stage,attacks, cymbals, decay, detail...the whole shebang), then how can it be not musical. Fluidity...get some decent 300b or 2A3....I'll wait for the full review from 6moons and bite the bullet for W4S.
Though DAC chips have a basic sound.....you cannot judge a DAC chip by someones implementation. The ESS DAC can sound way more "musical" than heard in the stock W4S and the 1704 can sound more "detailed and dynamic" than most implementations..........I cannot wait to get ahold of one of these DAC 2s and see what can be done.
